Hi Dan,
Thanks for answering !
I guess the only thing missing is the obvious absence of the returns or "switch legs" back from the foot switch.
Im trying to figure out that myself but these switches seems to be very hard to understand for me
It's a bit unclear too, just how you'll wire the capacitor.
I have one amp (built from amp kit) and I tried to imitate the switching from there but can't figure it out exactly. That amp has the cap from the diodebridges ground to the output leg and it works wonderfully.
 It will need to live between the + and - lines of the rectifier.
Ah, ok see above.
Which heater winding are you using?
It is the normal 6.3VAC (if I understand the guestion).
 If your transformer has a 5 volt winding for a rectifier tube you'll get 7 volts from a bridge rectifier and a capacitor entrance filter. If you use the 6.3 volt windings as shown you'll get 8.82 VDC. Neither voltage would be ideal for five volt relays. A voltage doubler on 6.3 volts gets you 15 volts.
Should I put a small (50R 2W) resistor between the diode bridge and the 5V regulator( TO-220 boxed) ? (
http://pdf1.alldatasheet.co.kr/datashee ... 805CV.html )
Mouser has Magnecraft relays with 6VDC coils in both DPDT and 4PDT form factors. These will work fine at the 7 VDC you are planning.
I already bought four of these RY5W-K (165R coil resistance):
http://www.fcai.fujitsu.com/pdf/ry.pdf
One problem is that the relay will pull down a whopping 170MA (each relay)with a 40 OHM coil. Just run the numbers on all filaments and make sure that the windings can handle the extra load. They probably can; most likely being in the neighborhood of 6.5 Amps.
Ok.
Just remember that the outlet receptacle and plug as well as the switch housing must all remain isolated from the chassis. That is true of either the DC or AC relays fed from the main transformer.
Ok, I'm going to use only the 5 pins of the female (chasis) and male (foot switch box) XLR's. I leave the ground pin unused.
You may be better off just buying a purpose dedicated transformer with all those relays.
I'll have to think about that if the current setup does not work.
I'm going to power the leds with 9V battery.
Also I could use a little help with those A, B, C, D, h pins versus 1, 2, 3, 4, 6, 7, 8 pins - how should they be wired ? And how the relays and the onpanel dpdt's connect ? (the picture above is updated)
I'm also willing to leave the bright switch off if it makes the switching better.
Good luck
Hope all this helps
Dan
Much appreciated. Thanks,
