New D-lator build 3 test configurations
Hi guys,
I'm in the middle of a D-lator build similar to the one I previously build ( https://tubeamparchive.com/viewtopic.ph ... highlight= )
This time I'm building 3 pieces because I want to test some different coupling caps, the 6PS OD is very hard to get in EU. I want to check some alternatives.
Also the power supply is modified with some slightly lighter filter caps than my previous build.
Coupling caps used in this 3 builds: Orange drop Ps6/ 225P series, Xicon MPP, Cornell Dubilier CDE DME series.
I'll post some pics asap.
Re: New D-lator build 3 test configurations
Some pictures; layout, drilling, eyelet board was the easy part. Adding waterslide decal to the frontplate was a nightmare. I will never use it again
Very cool!
I will be watching this as I intend to build one of these one of these days and want to know the best configuration and parts to use.
So I take it these will be the single tube, Dumbleator I style of loop?
Have you tried the Dumbleator II type?
By having three or four different builds, you will be able to instantly switch between them to hear the differences.
Keep the posts coming!
BTW; This is in the Netherlands a Rollator
Correct, single tube mono version. I didn't try/build the stereo version.Structo wrote: So I take it these will be the single tube, Dumbleator I style of loop?
Maybe in the future, it's got different values I saw in the schematics.
Erwin,
I love the newspaper...'Drechtsteden' ... Sigh. I grew up in 'Land van Valk, Dordrecht.
Why are you so keen on those caps? The Wima MKS4 series that is readily available in The Netherlands work great. And might be cheaper for you to use as well.
Have fun!
Jelle
Have fun!
Jelle
Hi Jelle,
So your also a "schapekop"
I already used a Wima cap for my Non-Hrm's od entrance with good result.
Only problem; because of the short leads of the WIMA's, the layout has to be very tight.
I might try it as well because I can't get my hands on a 0,047uF and a 0,1 uF Orange drop PS.
Thnx!
Erwin
Thnx!
Erwin
jelle wrote:Erwin,
I love the newspaper...'Drechtsteden' ... Sigh. I grew up in 'Land van Valk, Dordrecht.![]()
Have fun!
Jelle
Today I populated and soldered the boards.
With people like you doing this kind of research, there is no excuse for anyone on this forum to have bad tone. I am constantly impressed by the effort forumites like you put into wringing out every once of tone from a circuit, even one as benign as the loop. Let us know how it goes as I am also trying to improve the high end response of my built in d'lator.erwin_ve wrote:Hi guys,
Thanks Tonegeek! When I'm done I'll make some audio clips.Tonegeek wrote: With people like you doing this kind of research, there is no excuse for anyone on this forum to have bad tone. I am constantly impressed by the effort forumites like you put into wringing out every once of tone from a circuit, even one as benign as the loop. Let us know how it goes as I am also trying to improve the high end response of my built in d'lator.
Today I finished the first out of 3. This one is loaded with Xicon MPP.
Today I finished No.2 out of 3. This one is loaded with OD 6ps/225P. The last coupling cap is CDE dme because I couldnt get a PS serie for that one.
Today I finished the last one loaded with CDE DME. It's name is from a notorius pre 70-ies coffee machine
Very nice work and will be interesting to hear what you like or dislike between the three.
