Liverpool EL84 Bypass Cap
John C
Post by John C »
I see the Liverpool schematic on this site has a "220u" bypass cap at the output tubes. Is that supposed to be "22u"?
jaysg
Re: Liverpool EL84 Bypass Cap
Post by jaysg »
Nope. Those are 220uF caps. I bought Nichicons. Mouser # 647-TVX1V221MAD. There are probably lower ESR parts out there.
bcmatt
Post by bcmatt »
I know its rude of me to revive this, but I'm wondering about Voltage rating.
It seems most layouts say 100 Volts.
The Ceriatone seems to just have a single 63V Cap.
My problem is that I for some reason when I ordered parts, I ended up getting a couple 300Volt caps and a couple 50V caps (220uF).
I definitely don't have space for the 300V 220uFers,
So will the 50V ones be OK? They don't appear to belong to another build that I had planned, so maybe it was indicated that 50V is fine????
Any thoughts? What kind of voltages are to be expected there?
jaysg
Post by jaysg »
50 volts is fine. You can probably find an accurate voltage here somewhere. It's on the order of 11 to 13 volts.
Richie
Post by Richie »
i have a bunch of rubycon 220uf 35v.. 35v works fine in this spot..
bcmatt
Post by bcmatt »
Thanks guys! This is very good news indeed.
Things are pretty squashed over on that side. I'm trying to do both an Express and a Liverpool with the cap stack and VVR. I really should have went with cap cans.
Hopefully this means I can finish my first Liverpool without having to wait for any more parts to arrive. It's been a long road and a lot of waiting.
But I expect it will be my favorite amp of all time.
