Am looking for the mounting hardware like 124# I just need 4 Any Ideas where to find them?.. Thanks
Tony VVT
Mounting clips anyone
tubedogsmith
Re: Mounting clips anyone
try McMaster-Carr
Found em.. Thanks!!
Tony VVT
Tony VVT
Where? I stripped one of minetalbany wrote:Found em.. Thanks!!
Tony VVT
mcmastercarr.com
search weld nut
search weld nut
I've searched there, but I haven't found any with the mounting holes drilled out.ampdork wrote:mcmastercarr.com
search weld nut
I could be wrong but I think the name implies they are usually welded to a surface. If that is the case then you will need to drill them out yourself....or weld them ;O)
I use square cutouts and caged nuts with #10 screws...
That picture Talbany sent does look like a T-nut cut on one side and two holes drilled alright good catch xk49w your very resourceful.
