Some more clips of the 3 channel build (layout attached)
Bob-I
Post by Bob-I »
Where there's always more to do, I think it's starting to get there. Give a listen.....
I used the 4 - 10's in the Super Reverb build, Weber SigS 10's. Each clip is of one channel using 3 guitars, a MIM Strat, a Hamer EchoTone (335 style) and my #1 PRS Standard.
http://www.patmedia.net/bob-ingram/Allen/Channel1.mp3
http://www.patmedia.net/bob-ingram/Allen/Channel2.mp3
http://www.patmedia.net/bob-ingram/Allen/Channel3.mp3
Comments welcome.
Bob-I
Re: Some more clips of the 3 channel build (layout attached)
Post by Bob-I »
I finished up the layout. If you want to do a plain Dumble, without the Fender channel, just eleminate everything connected to V1.
I've got a list of additional changes that I'll be testing over the next few weeks, but the layout shouldn't change.
tonelab2
Post by tonelab2 »
Nice sound Bob. I'm hard pressed to pick which clean channel I like better.
I don't think I'll build a 3 channel just yet as I'm challenged just to get a 2 channel model together. Congrats on a nice amp.
Icetech
Post by Icetech »
You do the best layouts bob:) im sure ill be stealing some ideas off that...
Chad
Post by Chad »
I listened to all 3 clips and have to say that all channels sound Great to me. Awsome playing to Bob. After I get done with my first ODS I believe I have to do one based on your layout. Again wonderfull sounding amp. Thank's Chad
Normster
Post by Normster »
Sounds awesome, Bob! Cleans are gorgeous on both channels. Nice top end on the OD as well. I prefer "sizzle" on the top over "cream" for most of my stuff and your amp has definately got it. And...it's Crunchy!!! :)
I did hear a little bit of buzziness in the upper mids, but nothing obnoxious. What mid cap are you using?
Tdale
Post by Tdale »
How do you switch between the Fender and the Dumble channel?
Tommy
Bob-I
Post by Bob-I »
Tdale wrote:How do you switch between the Fender and the Dumble channel?
Tommy
There's a relay at the output of the channels.
Bob-I
Post by Bob-I »
Normster wrote:Sounds awesome, Bob! Cleans are gorgeous on both channels. Nice top end on the OD as well. I prefer "sizzle" on the top over "cream" for most of my stuff and your amp has definately got it. And...it's Crunchy!!! :)
Thx.
I have a .047uF in there now. I'm thinking of switching to a .01 or .022, but it sounds so good... I may just leave well enough alone.
Icetech
Post by Icetech »
Bob that fender clean channel blows me away.. before i thought the dumble one was better... think im losing my mind:) the fender one is mp3 #1 yes?
Bob-I
Post by Bob-I »
Icetech wrote:Bob that fender clean channel blows me away.. before i thought the dumble one was better... think im losing my mind:) the fender one is mp3 #1 yes?
You just might be losing your mind.... or the different speakers might have changed the charactor of the channel.
Yes clip #1 is the Fender channel.
Once I was able to crank it up a HeeBee's today I found that the Dumble clean is not as clean as the Fender clean. There's a grainyness to the Dumble clean that isn't in the Fender clean. The Fender stays crystal clean up to about 6 on the dial.
Icetech
Post by Icetech »
bob, if you had to choose 1 tone stack.. the dumb or fender.. what do you think you would go with? from hearing yours the fender sounds better to me and looks easier to wire....
I have mine apart right now and am trying to decide on a stack to use.. i had sheldons in there, but i think i messed it up or something.. the mid seems to control if i have bass and mid.. kinda odd:)
Bob-I
Post by Bob-I »
Icetech wrote:bob, if you had to choose 1 tone stack.. the dumb or fender.. what do you think you would go with? from hearing yours the fender sounds better to me and looks easier to wire....
For Overdrive the Dumble is far superior, the clean tone is great on both but the Fender has more range.
I drew up this layout awhile ago. It's pretty easy to follow. I'd rip all the wires out of yours and start again using this layout.
Also, if you can post pictures it might help to troubleshoot.
Icetech
Post by Icetech »
thanks.. i will do it off the layout you have there:) clears it up a bit.. i have a list of changes to make then i will tkae a pic or 2.. thanks again for the help.. Im feeling like the special kid on the short bus around here:)
Icetech
Post by Icetech »
thanks a ton bob! i have a very well working tone stack now.. and sounds pretty good too:) I just took some pics.. not that great though. im horrible with a camera...
http://mywebpages.comcast.net/roadrebel/amp/ampleft.jpg
http://mywebpages.comcast.net/roadrebel ... pright.jpg
one odd thing though.. my OD channel has gone quiet.. like half the volume of the clean channel.. might be a cold solder joint or something... gonna keep lookin..
Also... i have a like "fuzz" around the notes.. mainly if you attack hard, its on the clean channel and the OD channel.. kinda sounds like when you keep playing after hitting the power switch.. that draining caps sound...
Doh.. and i forgot to put that 4.7m from treb cap to ground.. will do now.. I am curious though.. 4.7 being a TON of resistance.. what does that do exactly?
