HRM with external adjustments.
phsyconoodler
Post by phsyconoodler »
Why doesn't someone add the controls for the HRM to a separate outside EQ rather than inside the amp?
I'm going to do this on my next build and see what happens.
Crystal latice or vacuum,that is the question.
benoit
Re: HRM with external adjustments.
Post by benoit »
There was a thread about this a while back, escapes me what the name was. It might have actually been tucked in the thread about eliminating controls rather than adding.
dave g
Post by dave g »
I'm almost positive Carol Ann amps are set up this way. If you've got the room on the front panel, I see no reason not to.
Bob-I
Post by Bob-I »
I did that once, but moved them internally later to clean up the front panel. They can be so sensitive that the slightest nudge can make the tone unusable. They're also very interactive so a touch on the treble means the mid and bass are way off.
The main tone stack seems to be all that's needed. JMO
brownnote
Post by brownnote »
I'd have to agree with Bob on this one.
If you had PAB tied to the OD so it's always in PAB when you switch over to OD, you could panel mount the HRM and have fairly independent tone controls but, given the ability of the standard HRM tonestack to dial in bad sounds if mis-adjusted, you're probably going to want to get creative with how you set that up.
Remember kids...Always adjust for minimum smoke!
D'Lite Kits: http://store.bnamp.com/dlitekits.html
