martin manning wrote: ↑Tue Feb 21, 2023 8:50 pm
R.G. wrote: ↑Sun Feb 19, 2023 10:52 pm
Unless the question of whether you and/or anyone else who participates in it can first demonstrate the ability to  tell by hearing alone
1- whether a change has happened or not
2- whether it's better or worse in their opinion if they think something changed, let alone whether #17 is better than #5
Edit: 2A - and whether #8 is better or worse or no change on unknown repeats of that part
3- with an accuracy much better than random guessing
then auditioning subbed-in parts doesn't tell you much, if anything.
This is where I'm at. Given the propensity of the human psycho-acoustic system to enhance the information appearing at the eardrums, I'm yet to be convinced without a rigorous test such as this.
I am happy to volunteer myself for those studies
I am also happy to be trust my own ears when I swap  identical value resistors and prefer one over the other, and I subsequently enjoy myself more and play with more inspiration . Obviously this sort of statement doesn’t prove itself , but it’s a dynamic of tone that ultimately can’t simply be ignored within the entire equation, and truly the one that arguably matters the most .
I think of it all this way : if I could build an amplifier and make it sound exactly the way I want utilizing nothing but the most reliable bulletproof and industry approved components I would without batting an eye .
If that was  solid state footprint amp I would be in heaven . Before I built my own amps I tried everything I could to avoid tube amplifiers . I wanted reliability and consistency, something I could not get with the tube amps that I had available. Tone was the trade off .
 By initially following the technical advice touted by most techs and engineers  I tried this approach most of my youth. Building amplifiers specifically to achieve the sound I wanted to hear when I performed and recorded music ,  this method never yielded what I wanted .
Only when I began actually looking inside of the amplifiers I liked, and stopped reading just schematics and just buying only from places like CEDIST did I finally start hearing what I wanted to hear . Based on many people’s convictions this is purely psychoacoustic in nature. Whereas I can’t pretend to detail and quantify every technical reason for every choice, I can measure the results when playing fairly easy.
If it feels and sounds inadequate I get tired . Lazy. Over it . Bored. Grumpy .
It’s simple . If it’s nice I feel invigorated and play for hours on end . It’s like coffee. Dopamine surges . Happy.
Fwiw Still haven’t gotten that feeling from an amplifier built by modern manufacturers .
