A while ago I got my hands on a Peavey Deuce VT (solid state preamp, 4x6L6GC fixed bias power amp) and decided to do a complete rebuild.
At this point the amp is up and running with parallel 12AX7 input stage -> james tonestack -> EF86 -> 12AT7 LTP phase inverter and 2x6L6GC self-biased power stage.
I'm having problems driving the power tubes to full blast, and I have to really abuse the preamp to get the 6L6GC's to clip even slightly. I suspect it's the plate/screen voltage or output impedance that limits the performance and I need to get this confirmed. I've tried a lot of tweaks in the LTP to ensure it doesn't clip prematurely and thus limit signal swing, and I actually wired a 50k LIN pot in place of the tail resistor and a 5k LIN pot in place of the cathode resistor. Surprisingly there were no audible difference between 50k tail and ~10k tail, although I settled for 12k as it balances the tride halves very well and it gives a lot of headroom just taking up 10-15% of the available B+ voltage. Long story short I think the LTP has enough potential to drive the power tubes well beyond full power.
The output transformer has two output taps with impedance ratios of 445:1 and 230:1.
For the 445 tap the possible impedances are 1780, 3560 and 7120 plate-to-plate with 4, 8 and 16 ohms load respectively.
For the 230 tap the possible impedances are 920, 1840 and 3680 plate-to-plate with 4, 8 and 16 ohms load respectively.
At this moment I'm running 16 ohms load into the 445 tap for 7120 ohms (3680 ohms per tube) which I believe is the most correct impedance for this build (see load line below). With around 400V on the plates it seems I'll have to bias really cold to avoid the load line exceeding plate dissipation, although 400V plate voltage seems quite normal for these tubes.
Running four 6L6GC's would naturally allow a few more possibilities impedance-wise, but I'm not sure if the heater windings can withstand the extra current to the preamp tubes. I've asked Peavey tech support but they didn't have the specs anymore and I don't wanna risk frying the windings.. TAD makes an aftermarket tranny for the Deuce VT which has a 3.8 amperes heater rating. That leaves 0.2 amperes for preamp tubes.. Is it safe to assume that Peavey overbuilt the tranny enough to safely run the preamp tubes in addition to the four 6L6GC's?
Anyway, my observations/ideas so far:
- Lower the screen voltage to get the g1 0V knee just above the load line. Increased sensitivity makes the tubes easier to drive, and it'll match the Zout nicely, right?
- Lower the plate voltage to allow lower output impedance which would recuire a pretty big zener/resistor.
- Fixed bias. I read somwhere that cathode bias should not be used with very high plate voltages because it's hard to find OT's with correct impedances, but I can't see the logic in this (so far). Anyone know if this is true and care to explain why?
Initially I thought I had a fairly good grip on how to set up a power stage like this but I think I might need some input.
