100 watt BM Build
dcribbs1412
100 watt BM Build
Post by dcribbs1412 »
Finally got her up and going. Had issues with loop and hum.
Nice and quiet now
This one has very nice tones, might keep it.
Builds seem to go slower and slower. Need to clean up heaters and wiring.
She may go into a nice Mahogany head cab
D
pics:
Re: 100 watt BM Build
Builds like this go slow is right in my case.
Looks good!
Colossal
Post by Colossal »
Wow, that's a beauty! Lots of work in there for sure. Bet it sounds great!
Matt J
Post by Matt J »
Looks awesome! I can't wait to see it in the cab you get for it!
- Matt J.
dreric
Post by dreric »
Great looking build!
I see the HRM tone stack is off the main board. Is that a loop mounted above the board?
Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
dcribbs1412
Yes
Etched board for loop
Ran the HRM off pre board like Ceriatone
Seems to work good very noise free
D
Sent from my iPhone using Tapatalk
dcribbs1412
Got her in a cab
Mahogany with Alder front and back with a few coats of Tru-Oil
Debating about black metal corners?
She is a very sweet sounding amp.
Recommend giving the BM circuit a try.
D
10thTx
Post by 10thTx »
That is one beautiful wood cab! Thanks for sharing the photos. Magnificent job. I certainly would NOT put black corners on that amp head. It looks spectacular the way it is, IMO.
With respect, 10thtx
Matt J
Post by Matt J »
That looks AMAZING!! Did you make that cab or did you get someone else to do it? That is seriously cool!
- Matt J.
dcribbs1412
10thTx wrote: Fri Apr 27, 2018 1:09 am That is one beautiful wood cab! Thanks for sharing the photos. Magnificent job. I certainly would NOT put black corners on that amp head. It looks spectacular the way it is, IMO.
Thanks 10thtx
No corners it is!
Matt J wrote: Fri Apr 27, 2018 1:17 am That looks AMAZING!! Did you make that cab or did you get someone else to do it? That is seriously cool!
- Matt J.
Thanks Matt
Buddy of mine has a wood shop (he 's a retired cabinet maker) with a nice dovetail machine.
He designed and cut/routered the cab with specs from here
I put it together..... lots of sanding
D
Post by Mark »
The cab is just out of this world, very beautiful!
Yours Sincerely
Mark Abbott
erwin_ve
Post by erwin_ve »
Beautiful cab, like a AAA flame top on a guitar!
Can you give some clues how you solved your hum issues?
dcribbs1412
Thanks Guys
Only been using a strat with single EV 12L in a ported cab but really like the tones from this circuit.
Amp sounds as good as she looks IMO. The internal loop with switchable bright caps on both send and return pots really adds versatility with FX units and volume.
D
erwin_ve wrote: Fri Apr 27, 2018 12:06 pm Beautiful cab, like a AAA flame top on a guitar!
Hi erwin
combination of loop ground moved to loop tube area(not at pre amp ground area) and adding small pf cap on send pot, seemed to do the trick.
Also replaced a bad Vol pot.
D
stelligan
Post by stelligan »
That cab is spectacular! Congrats :!:
