Spitake #15 (Spitfire Type Build)
BLT
Post by BLT »
My first amp build was a rendition of the old Fender MusicMaster Bass amp that I have now converted into essentially a Spitfire type of amp. The chassis is 12 X 7 and I figured correctly that it would be a tight fit.
BLT
BLT
Re: Spitake #15 (Spitfire Type Build)
Post by BLT »
Here's a few more.
BLT
BLT
Post by BLT »
The end product.
BLT
BLT
Post by BLT »
I decided to change wire for the filaments to solid core 18AWG. The stranded PVC I was using just couldn't take the heat, and I couldn't stand the look of it.
BLT
BLT
Post by BLT »
Voltage Chart
BLT
Looking good!
A friend of mine had an old Spitfire and I remember liking it when I played through it.
BLT
Post by BLT »
I know it's been said if you don't have Matchless iron, it's not going to sound like a Spitfire. So I used the preamp layout, added some Z touches in some places and some of the ideas in the last Rocket I built, so I would suspect it doesn't sound that much like a Spitfire. It certainly beats what was in there before this build. I'm now in the process of changing the tone stack to something Z uses in his Stangray and Ghia. I'll try and see what values work best for this layout. But thanks for the look.
BLT
BLT
Post by BLT »
Finished schematic.
BLT
BLT
Post by BLT »
Hopefully the last pic to update tone control change.
BLT
WRC34
Post by WRC34 »
Looks very nice! Which type/model transformers did you end up using?
BLT
Post by BLT »
Heyboer 18W HTS-9178 PT and Classictone 18W OT.
BLT
