New tube tester day...and some confusion?
beasleybodyshop
Post by beasleybodyshop »
Hey folks. I just recently picked up this 70s era B&K 607 solid state tube tester. I've been learning how to use it, and came across some instruction that was a bit confusing, could someone here enlighten me? I tried to test a 12AX7. In the tube chart there was a little asterisk by the tube that notes to check the front page. I've attached a photo of what it tells me to do next. Is it just me or is this confusing as hell? Connect what leads to where on the tube???
beasleybodyshop
Re: New tube tester day...and some confusion?
Ok, I may just be an idiot. Lol. The asterisk may just indicate that it's more than one amplifying element...
The Ballzz
Post by The Ballzz »
beasleybodyshop wrote:Ok, I may just be an idiot. Lol. The asterisk may just indicate that it's more than one amplifying element...
Yepper,
It takes one to know one! :P I believe that it is just that bottom section pertains to your situation, just in case you didn't know that a 12AX7/ECC83 was a multi section tube!
Happy Testing, :D
Gene
Post by Stevem »
The best way to test a tube with this tester is after the initial test to drop the heater setting down and check how much emission the tube drops off to, this is a test of tube life left.
Even before you do any testing at all check you wall voltage and make note of it as a 4 volt drop from normal due to a the high load of a summer day will throw things off a good bit!
Those kind of testers are not very accurate.
More of a Good/ Bad type test.
