mojo 30% taper pots?
Chris Brown
Post by Chris Brown »
Has anyone tried the 30% taper pots from mojotone? I just grabbed a couple of 250Ks and a 500K for my upcoming build. The 500K is knurled only but the 250Ks are solid shaft.
ToneMerc
Re: mojo 30% taper pots?
Post by ToneMerc »
Chris Brown wrote:Has anyone tried the 30% taper pots from mojotone? I just grabbed a couple of 250Ks and a 500K for my upcoming build. The 500K is knurled only but the 250Ks are solid shaft.
I will have to try a couple and see how they plot against the new CTS 30% tapers from the guitar parts outfit in Germany. The German outfit the tapers are normally about 27-28% and shafts are knurled, but I have used shaft bushings on them. If these from Mojo work out, there's a domestic supply and it beats searching the earth for vintage Fender pulls for a correct taper pot.
Now only if they will get a batch made in 1Meg!!!
TM
Charlie Wilson
Post by Charlie Wilson »
Hello, Fender sells CTS 30% taper pots in 250k and 1 meg. They call them J taper.
CW
jelle
Post by jelle »
Who wants to do a run of these, incl 1M-J? Full size, solid shaft?
Chris Brown
I can only find 1M J taper as pcb mount / snap in... looks like angela had some 24mm solder lug types but they are out of stock
dreric
Post by dreric »
http://www.ebay.com/itm/Fender-Bassman- ... 19e741016a
4 x 2-35 250K
3 x 999K
real cts, real 2-35 taper
I got some of these. They need to be cleaned but I haven't found a dud yet.
Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
Chris Brown
dreric wrote:http://www.ebay.com/itm/Fender-Bassman- ... 19e741016a
4 x 2-35 250K
3 x 999K
Good find! I just ordered one... guess I need to dig out the deoxit.
Chris Brown
I'm guessing HD is H taper and D shaft
ToneMerc
Post by ToneMerc »
Chris Brown wrote:I'm guessing HD is H taper and D shaft
Linear taper, solid shaft
TM
Chris Brown
TM
that's no fun :P
FuzzFaceBuilder
Post by FuzzFaceBuilder »
Here's the info on the J taper pots:
www.ctscorp.com/components/Datasheets/450g.pdf
Charlie Wilson
Hello, CTS labeled their linear 1 meg pots 999k to make it easier to tell them from audio ones.
CW
Aaron
Post by Aaron »
So H is 25% taper?
I just bought a couple anyway.
Charlie Wilson
Sorry Chris, your question was is H taper 25% and I don't know but I do know anytime you see the 999k pots they are linear. I purchased one also.
CW
Last edited by Charlie Wilson on Fri Aug 15, 2014 3:56 pm, edited 2 times in total.
Chris Brown
Aaron wrote:So H is 25% taper?
As far as I can tell Fender H taper is 25% but the HDs aren't H taper.
5 each for 2-35 is awesomeness... I haven't been able to find any that I could afford until now. :D
