Dumble Switching Question
wattsup
Post by wattsup »
I know this might be sacrilege but is there a way to do the switching for the footswitch with a 1/4" jack instead of the standard? I thought I saw a Dumble like that once but don't know where I saw it.
ampgeek
Re: Dumble Switching Question
Post by ampgeek »
Yes!
I have used Cliff type TRS (tip, ring, sleeve) sockets and stereo plugs for two relay switching systems many, many times including my Dumble'esq builds (OD, PAB functions).
Not sure if a greater than 2 function option using 1/4" size exists though.
Good luck,
Dave O.
wattsup
Post by wattsup »
ampgeek wrote:Yes!
Good luck,
Dave O.
Thanks Dave O. Are there any examples of that type of wiring on here that you can point me to?
Smitty
Um Hmm
Post by Smitty »
If you've got everything grounded right, use a regulated relay supply with pop cap and diode you can use the number two jack hole on old Fenders with a regular Switchcraft stereo jack (grounded to the chassis).
10thTx
Post by 10thTx »
Lots of good information on relays and switching here:
http://el34world.com/Forum/index.php?topic=14348.0
Including how to use a stereo 1/4" jack for two button footswitch.
With respect, 10thtx
ic-racer
Post by ic-racer »
The Fender amp I modified to ODS circuitry had two 1/4" jacks and I used them as follows:
Jack 1 (mono isolated ground)
PAB LED POWER to jack 'ground'
PAB RELAY POWER to jack 'tip'
Jack 2 (stereo grounded)
OD LED POWER to jack 'ring'
OD RELAY POWER to jack 'tip'
GROUND to jack 'ground'
That is still the usual 5 wires. I think there are ways of doing it with less wires than 5 but I don't know it off hand.
https://tubeamparchive.com/download/file.php?id=4402
"You feel like you're floating on a football field filled with marshmallows." -Dumble
wattsup
Post by wattsup »
Thanks 10thTx and ic-racer that's exactly the stuff I am looking for.
