DIY Airbrake...
Re: DIY Airbrake...
Me too please.  My neighbors have no sense of humor.
						Re: DIY Airbrake...
Thanks to all three of you who sent it to me.
				poipounder57
Re: DIY Airbrake...
I rec'd my parts.  Getting ready to put it together...just have one question.
What gauge wire should I use? Thanks!!!
				tweedeluxe
Re: DIY Airbrake...
I used 18ga because thats what I usually use for speaker cable.
						Re: DIY Airbrake...
This photo of the real deal shows 18AWG.
						Re: DIY Airbrake...
Can I get a copy too please???
Edit: I've received it, thanks!
						Re: DIY Airbrake...
Or can I buy one already made up???
Craig.
						Craig.
Re: DIY Airbrake...
looks pretty cool guys
can somone please mail me the schematic.
thanks
lars
thanks
lars
				PaisleyTube
Re: DIY Airbrake...
Me too please, many tia!!!nickt wrote:Sent via PMLeftyStrat wrote:I'd like a copy, TIA
Chris
Love, peace & loudness!
Re: DIY Airbrake...
Thanks Groovenut
Regards, Craig.
						Regards, Craig.
- RJ Guitars
It sounds better when it's louder?
Well, this has been a long enduring thread and there ought to be a bunch of airbrakes out there.  I'm curious what people think of them??
I've been attempting to get bedroom volume and big league tone for a few years now and I'm just about to convince myself that it's not gonna happen... not to say I haven't got some cool tones at reasonable volume, just seems my ears tell me that two watts cranked isn't a scale model of 50 watts cranked.
When I get the airbrake to squeeze down a Fender Deluxe, it seems sorta buzzy and not all that cool... as I back off the brake, the tone just seems to get better as the volume gets louder.
Anyone else have a similar experience?
Do you think it works better on some circuits than others?
rj
rj
http://www.rjguitars.net
- geetarpicker
Re: DIY Airbrake...
I have a Dr. Z Airbrake.   I disconnected the orange drop cap in mine.  If anything that seems to ADD to the buzz at lower levels.   Still, the Airbrake really isn't that good turned down low and for that I actually think the THD is a little better.   However the Airbrake does work well with lower wattage amps where you only need to take off say 2-6 db.  Then you can even tweak the resistor clamps inside to totally dial in what you need.
To my ears the Airbrake is brighter and clearer, and the THD darker. Sometimes I pick between the 2 just on tone. Sometimes however I've even run both in series when I run a 100 watt Marshall. I'll run the THD 1st, and take off about 4 or 8 db. Then I run the Airbrake to take it down just a couple more clicks never getting to the reostat setting which I don't really like.
That's my take on it.
Re: DIY Airbrake...
Glen-
Did you use an attenuator on the video clips you did recently? It doesn't sound like there is anything between the wreck and the cab, but I thought I would ask. Beautiful stuff by the way!
Thanks,
Law
Thanks,
Law
