Who Sells Circuit Boards?
Guys,
There used to be a post in the For Sale area about someone that sells D-style circuit boards which somehow seems to be gone. Could someone please post or send me a PM with the link to the guy's website?
Thanks,
Gil
Thanks,
Gil
- boldaslove6789
Re: Who Sells Circuit Boards?
Greg D.C.
Can you dig it?
						Can you dig it?
Thanks Markus and Greg!
Gil
						Gil
Oh NOOOO!!.. Gil have you fallen off the wagon again.. If so what do you have in mind!!ayan wrote:Guys,
Thanks,
Gil
Well, I don't feel like cutting, drilling and etching...but I'm kind of curious about trying the "bright on clean only" mod. I guess this constitutes a bit of a relapse on my part.
Gil
						Gil
talbany wrote:Oh NOOOO!!.. Gil have you fallen off the wagon again.. If so what do you have in mind!!ayan wrote:Guys,
Thanks,
Gil![]()
Bright on clean only is a cool feature!..What value and type cap were you looking at?..Good Luck..ayan wrote:Well, I don't feel like cutting, drilling and etching...but I'm kind of curious about trying the "bright on clean only" mod. I guess this constitutes a bit of a relapse on my part.
Gil
Thanks,
Gil![]()
I use 120pF ceranic discs in my amps...I could try maybe 100pF SM instead, probably "prettier" sounding.
Gil
						Gil
talbany wrote:Bright on clean only is a cool feature!..What value and type cap were you looking at?..Good Luck..ayan wrote:Well, I don't feel like cutting, drilling and etching...but I'm kind of curious about trying the "bright on clean only" mod. I guess this constitutes a bit of a relapse on my part.
Gil
talbany wrote: Oh NOOOO!!.. Gil have you fallen off the wagon again.. If so what do you have in mind!!![]()
Tony![]()
Yes, that is what I use as well, 120pf SM.
I run a pair of EVM 12L's.
I have to add that for me, using a dual humbucker guitar that has Dimarzio 36th Anniversary PAF's in both positions, I really prefer the neck pup for clean tones and that bright on clean cap really enhances that.
It adds a nice snap to the tones.
The bridge pup is of course not as full sounding on clean but at a gig it might be ok.
In overdrive, the bridge pup sounds great.
My guitar has a five way switch which splits the pickups for a variety of sounds.
- Luthierwnc
I've got my version of the bright-clean-only on a thread that is running concurrently:
https://tubeamparchive.com/viewtopic.ph ... c&start=15
It works really well and doesn't need any extra panel space (or holes). It does need an extra relay, though.
Cheers, Skip
Cheers, Skip
I also like the idea of " raw" on clean only... Might as well try that too if I will be doing the bright mod.Luthierwnc wrote:I've got my version of the bright-clean-only on a thread that is running concurrently:
Cheers, Skip
Thanks,
Gil
One thing I remember trying way back was 2 different GNFB resistors on a relay.. Have a little less feedback on the clean channel to give it some brightness life and more harmonic content..Then clamp it down a bit keep it smooth and tight on the OD..I thought it worked pretty cool..
				bluesfendermanblues
I've done the "bright on clean" (as well as "mid on realy") in both a #183 and #102 build.
Decided to make a new realy board for the four realys.
Below are pics of implementation in my #183 (sorry for the messy pic qual), but just menat to illustrate the idea.
