Which 6G6 Bassman?
- LarryLarry
Which 6G6 Bassman?
I'm thinking of building a 6G6 Bassman and I'm not sure which to build.  I had a few of the blonde Bassmans with presence controls back in the day and loved the gain, but I'm not sure which circuit they were.
I have the PT and OT, but will need to get a choke. Anyone know which choke it calls for? 4HY?
Re: Which 6G6 Bassman?
I'm gathering parts for two of them, basically a 6G6B with tube rectifier option. One will be wired as G6 with a tube rectifier and have the s/s rectifier plug in and my personal one will toggle between s/s and tube rectifier.LarryLarry wrote:I'm thinking of building a 6G6 Bassman and I'm not sure which to build. I had a few of the blonde Bassmans with presence controls back in the day and loved the gain, but I'm not sure which circuit they were.
The choke is 22699( 4H, 90ma), same as the Twin
TM
I recommend 6g6b, the 6g6a bass circuit clips and farts badly when turned up high
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
I love the sound of the 6G6B. I've never built any of the others, althoughI did hear Lublin's SF Bassman, and it rocked hard also (I know, that one is not a 6G6).
I have built a fairly traditional 6G6B, although with bigger iron, and a SS rectifier slug plugged into the tube socket (it can run with a GZ34 also) and it is wonderful. I have also built a Bass channel only version as a 1x12 combo with diode rectification. The amp tone is great, although I have been having a serious hum problem since it was built that I haven't yet figured out (obviously not the circuit's fault.
The Bass channel is like having a really cool Marshall varient, while the Normal channel is like a fat, somewhat agressive Fender tone.
- LarryLarry
Thanks guys!  Probably go with the 6G6-B.
						- LarryLarry
Anyone know of a layout and/or schematic that are decent quality?  All that I find are blurry...
Hope this helps.
By the way - a VVR works nicely with this circuit if you are so inclined.
http://www.el34world.com/charts/Schemat ... N_6G6B.pdf
If you're still looking for iron for your build:
http://www.ebay.com/itm/Output-transfor ... 256fa94be2
http://www.ebay.com/itm/Power-transform ... 256fa9518d
Mag Comp iron at bargain prices.
Gomez Amps selling off inventory.
- LarryLarry
Awesome, thanks!  I have a Weber WO22798 PT that looks up to the task, and a nice big OT from a Knight mono amp that ran 2x5881s and a GZ34, with 4/8/16 secondaries.  Gotta get the choke though...
UPDATE, just bought 1 of his chokes for $17 shipped...
- LarryLarry
Anyone know if it's ok to use a IN5399G diode (1000v, 1.5A) in place of a IN4007 (1000v, 1A)?
Is the treble pot on the normal channel (350k/70k tap) available, or is there another way to sub it?
Thanks in advance.
									Thanks in advance.
Horacio
Play in tune and B#!
weber sells these. pm me your address if you want one in the mailalvarezh wrote:Is the treble pot on the normal channel (350k/70k tap) available, or is there another way to sub it?
Thanks in advance.
4x12" w/H75s
4x12" w/H75s
Also Doug Hoffman;alvarezh wrote:Is the treble pot on the normal channel (350k/70k tap) available, or is there another way to sub it?
Thanks in advance.
http://www.hoffmanamps.com/MyStore/perl ... =136394652
I've built many 6g6b-type circuits utilizing just the clean/guitar channel.  Great sounding circuit for sure.  Add reverb, and bam, tonal heaven using a gretsch or tele.
									I Hate being bi-polar; It's awesome!
						- LarryLarry
Anyone on the diode substitution question?
