Structo wrote:Yes, the Mouser catalog definitely has a learning curve to using it.
Especially since they really don't show very good images of the products or it may be totally wrong.
I have ordered many things that I didn't want or could use.
After a while you get the hand of what they have and what they don't.
But I always have to order from multiple sources to get what I want.
I have a local surplus place that has those NTE components.
Not sure who makes those metal film but they seem to be pretty consistent.
I use the Vishay Dale RN65D series for the plates.
Hi Structo,
Do you have a link to the RN65D in Mouser? I might try em if I could them in mouser.com
I swear Mousers catalog search feature is the most non-intuitive feature. I order stuff for my business and if you don't have a part number from a prior invoice you can't find it worth a darn. All I could find in 100K resistor was 1/4 watt
I use PRP metal films for cathode resistors (not from Mouser) at least I can find what I am looking for without tearing my hair out.
This is the RG 400 cable. http://www.aircraftspruce.com/catalog/e ... ctors6.php
I made up 2 cables for my Dumblelator. 5 ft. each. about 160pf for each cable. At the time ,I didn't want to cut too much highs, but I could have went 6 or 7ft.
Structo wrote:Speaking of Tantalum caps.
Have any of you auditioned different types of caps for the presence cap?
I have had a 1uF Tant in there as well as an 1uF and 2.2uF aluminum E cap.
Didn't really notice any difference in tone.
I thought I read somewhere here that HAD has the 1uF tant cap polarity in backwards in #124?
Up until the last few I was using small poly caps and honestly I can't tell any difference between the poly and tant. Yes, the cap in #124 is backwards.
