Bias Pots
Alexo
Bias Pots
Post by Alexo »
Anyone know a good source for 25K or so panel-mount screwdriver-slotted linear pots?
CE only has the 10K Fender versions, and Weber has the 25K ones I like, but there must be other options out there..
buddyrama
Re: Bias Pots
Post by buddyrama »
Parts Connexion in Canada has a very substantial looking one from Connex.
coolidge
Re: Bias Pots
Post by coolidge »
Re: Bias Pots
I like the 25K PEC locking pot with short slotted shaft for that.
http://search.digikey.com/scripts/DkSea ... &x=20&y=15
It has a locating pin to keep the pot from turning when you tighten the mounting nut.
Good idea to use it as I have ruined a pot before when tightening it.
I use two of these in my 100w Dumble clone.
Alexo
Re: Bias Pots
Post by Alexo »
Thanks a lot, guys!
diagrammatiks
Re: Bias Pots
Post by diagrammatiks »
I've been using a bunch of nos clarostats, pecs, and centralabs.
allied sells these pots by eti systems
http://www.alliedelec.com/search/produc ... KU=5220112
which are new production and readily available, i'm gonna switch over when my stock runs out of the nos stuff.
Re: Bias Pots
Why would you use that one when the PEC is cheaper and rated for 2W as well?
diagrammatiks
Re: Bias Pots
Oh I duno. Do you have a link to the PEC supplier?
I was just creating a list of options. I'm not about to run out of claro's for a while.
whoops sorry just saw your link above.
I hadn't gotten to digikey's catalog yet. Only mouser and allied so far.
Digikey's next.
Re: Bias Pots
Sorry I didn't mean to come off snarky.
I was just curious why you would want to pay more for a similar pot.
I have used quite a few of the PEC locking pots for bias and I like them a lot.
If you tighten the lock nut down just a bit it puts enough resistance on the shaft to prevent unintended movement but you can still fine tune the bias with the proper screw driver.
coolidge
Re: Bias Pots
Post by coolidge »
diagrammatiks wrote:I've been using a bunch of nos clarostats, pecs, and centralabs.
FYI those ETI's are PEC pots. I see PEC pots pop up under all sorts of re-branded names.
coolidge
Re: Bias Pots
Post by coolidge »
buddyrama wrote:Parts Connexion in Canada has a very substantial looking one from Connex.
That is yet another PEC pot
diagrammatiks
Re: Bias Pots
good to know coolidge!
I wish tubesandmore here sold more of the pec pots.
