Is there a SE 6L6 Wreck out there?
- RJ Guitars
Re: Is there a SE 6L6 Wreck out there?
Yes that plays toward my next question - does the PI "flavor" the tone in any way or is it just a mild boost? maybe a 12AU7 or something like that might do the trick?
rj
rj
http://www.rjguitars.net
JamesHealey
or run the pre-amp on much lower voltages so it clips earlier this will essentially change the bias point of each stage but I've got a nice single ended wreck I made for a friend that runs on a B+ of about 230v.
ncusack wrote:If its a matter of gain could it be made up in the front end by paralleling V1 or does the PI make all the difference here?
That's my inclination as well - use that "extra" half-12AX7 and get some noise rejection as a windfall.
Any reason NOT to parallel V1???
While we're at it, does anyone know the tube count in a DLM? If there is a fake PI using a full 12AX7, there would have to be three 12AX7s.
I just saw the answer in a parallel thread:Zippy wrote:While we're at it, does anyone know the tube count in a DLM? If there is a fake PI using a full 12AX7, there would have to be three 12AX7s.
https://tubeamparchive.com/viewtopic.ph ... &start=300
Thanks, Mark!
Tube count:
2 ECC83 (GT Yugo)
1 EL 34 (Mullard xf2 )
1 GZ 34 (Mullard)
So no full PI in that build.
- RJ Guitars
I am disappointed to see that GZ-34 since I was hoping that we might be able to dismiss that expense of trying to find another one of those.Zippy wrote:I just saw the answer in a parallel thread:Zippy wrote:While we're at it, does anyone know the tube count in a DLM? If there is a fake PI using a full 12AX7, there would have to be three 12AX7s.
Thanks, Mark!
Tube count:
2 ECC83 (GT Yugo)
1 GZ 34 (Mullard)
se trainwrecks of various octal outputs
i built a 6l6 and an el34 and a 6v6 se version of the express as well as a 2x el84 liverpool. the se doesnt compress as much or clean up quite as well but they are pretty wicked anyway. i use my 5 watt 6v6 for bar gigs. it may be a little more than 5 watts , not sure. my fake pi is a simple gain stage using 47k plate r and 22k cathode r . same decoupling cap as stock pi in an express. works pretty good. my camera stinks but here is a link to youtube. http://www.youtube.com/watch?v=9uOlMVAybFw is the el34.
http://www.youtube.com/watch?v=YXE4Dofpieo is a live recording in my local drinking establishment with the 6v6 5watt.
- RJ Guitars
Great playing and very good sounding amps!
Thanks RJ.!I noticed you sub heading and truly started laughing out loud cause i say it all the time. pick two. I usualy draw a triangle and put one on each corner. ( i am a carpenter in real life ).
"GZ-34" in a 5-8w amp spells "stiff" to me and reinforces the idea that it's alright to go SS. Go ahead and calculate any delta V that you're going to garner from using a tube rectifier. Nadda. Nil. Zip.RJ Guitars wrote:I am disappointed to see that GZ-34 since I was hoping that we might be able to dismiss that expense of trying to find another one of those.Zippy wrote:I just saw the answer in a parallel thread:Zippy wrote:While we're at it, does anyone know the tube count in a DLM? If there is a fake PI using a full 12AX7, there would have to be three 12AX7s.
Thanks, Mark!
Tube count:
2 ECC83 (GT Yugo)
1 GZ 34 (Mullard)
RJ, I found a thread on the DLM where you had an unverified schematic. Im wondering if you've put together a working DLM since then and if so what kind of changes did you end up making.
+1.Zippy wrote:"GZ-34" in a 5-8w amp spells "stiff" to me and reinforces the idea that it's alright to go SS. Go ahead and calculate any delta V that you're going to garner from using a tube rectifier. Nadda. Nil. Zip.
You'll be able to get a degree of power supply compression when you really push the output stage into a heavy square-wave duty cycle, but you could replicate that with a a resistor, and it most likely wouldn't sound good by that point anyway even if it had the drive to reach that point.
