Finally finished the comprehensive 124 BOM. Could you check?
				Joost
- Location: The Netherlands or Holland. Whichever you prefer
Well, it took me many evenings to read the schematic, the layout and the real world pics of the actual 124 amp, and get from the generic Bill of Materials to this, made specifically for the 124 with skyliner update. In the generic, much was missing or needed changing. I also added the parts for the small Normster Dumbleator.
I also added the function of each part as best I could.
I also added the latest part number and link to where to get it in most cases
I would really appreciate it if you guys would check this thoroughly, so we can add this to the 124 files.
I have attached the loop I meant.
PS: who can point me towards the prober sliding switches for the back?
PPS: ***UPDATED file 1.1 -> scroll down***
						Re: Finally finished the comprehensive 124 BOM. Could you check?
That Dumbleator schematic is not the one recognized as being the most accurate.
I believe this one is the accepted one.
On the BOM the 6PS caps are polyester.
I believe the FET jack is the Switchcraft 14b.
I commend you on your efforts and it does take the existing docs a step further. However, unless one is going to use it a build sheet, it's still a generic BOM. Like someone said earlier, people tend to use whatever parts they like.
You still have several trhings to clean up....Carling pwr/standby switches, sprague axial caps
Also, I think intergrating the Dumblelator makes it convoluted.
TM
TM
				Joost
Thanks for the feedback guys. I'll check it out.
						Could you be more specific. English is not my native language so I might've made some translation mistakes. What do I need to change?ToneMerc wrote:
TM
Joost wrote:Thanks for the feedback guys. I'll check it out.
TM
Carling Tech, Toggle Switches, 15 A SPST (ON-OFF) Standby, Power
Sprague Atom 500V, 20µF Axial, Power Filter
Sprague Atom 500V, 10µF Axial, Power Filter
I would use Piher trimmers for the OD & PI
				Joost
Thanks guys. I changed:
-Dumbleator to new values and parts based on new schematic
-FET Input jack
-Piher trimmers
-Carling switch
-Sprague Atom Axial
Any other feedback welcome. Here is the new file, version 1.1
BTW, TM, I hear you, it's not a build sheet, but at least now all the parts are accounted for and I tried to point towards vintage correct parts as much as possible. Including the different types of resistors etc. So I hope this will help people a bit
-FET Input jack
-Piher trimmers
-Carling switch
-Sprague Atom Axial
might try Gabkits for cheaper Iron
Merc Magnetics site is higher priced than most of their dealers
But Im in USA
Either way those are going to be the most expensive irons, expensive paint job. IMHO
But Im in USA
Joost where are you located?
Please put your location in your forum profile.
This will help us help you in recommending parts that may be local to you.
				Joost
Ok great! Done. I'm in the Netherlands, Europe
You are the same Joost... We corresponded a few times back on the AGF when I was ordering my Ryan Mission Grand a few years ago. Nice to see you on the amp garage.Joost wrote:Ok great! Done. I'm in the Netherlands, Europe
http://agbamplifiers.com/
Dumble Clone Circuit Boards
				Joost
Hey Nice to meet you here. Yeah I'm the same guy. And it looks like I'll be ordering from you real soon !jborders5 wrote:You are the same Joost... We corresponded a few times back on the AGF when I was ordering my Ryan Mission Grand a few years ago. Nice to see you on the amp garage.Joost wrote:Ok great! Done. I'm in the Netherlands, Europe
