TwoRock EMMY PRO REPRISE..WITH CLIPS AND PICS.
As I said in the first thread, this E.Pro was modded by Bill with a few things I wanted. It has a switchable 330/500K treble cap, Dual reverb controls, 3 way mid and 3 way bright switch. Bright and Deep switch dedicated to cleans. The power supply was "sweetened", whatever that means. Also, midswitch put on foot control. This amp sounds AMAZING, and is one of my favorite D style amps. Its very very close tonally to Dumble #183. A little smoother, but not quite as harmonically rich. Its cleans, overdrive and reverb are excellent, and the loop which is switchable between parallel and series works fantastic too. Here are 2 clip I just did with the amp.
CLEAN CHANNEL: Les paul neck pup. straight in. SM57 straight into my Boss BR900.
http://www.soundclick.com/player/single ... 20119&q=hi
Overdrive channel doing Politician.
http://www.soundclick.com/player/single ... 97081&q=hi
Here are some pics. [img:533:400]http://pic20.picturetrail.com/VOL1427/1 ... 629733.jpg[/img]
Re: TwoRock EMMY PRO REPRISE..WITH CLIPS AND PICS.
Another pic.
[img:533:400]http://pic20.picturetrail.com/VOL1427/1 ... 629731.jpg[/img]
[img:533:400]http://pic20.picturetrail.com/VOL1427/1 ... 629726.jpg[/img]
[img:533:400]http://pic20.picturetrail.com/VOL1427/1 ... 629719.jpg[/img]
Mr. D
Nothing comes close to the E-pro. WOW!
and thank you for the gut shots....well presented.
PM
makrisp wrote:Mr. D
Thanks man! I went in last night and adjusted the HRM, then popped a telefunken smoothplate in slot 1. HUGE difference! Smoothed it out even more, and brought out more chirp on the top. The amp is KILLING!!
Will you post a few clips showing the reverb on different settings with the clean and od respectively?
Good stuff Tag.... Now please get a good recording rig!!
You can do it!!
You can do it!!
Thanks Scott. Amazing I got a compliment from you while playing an Emerald Pro!dogears wrote:Good stuff Tag.... Now please get a good recording rig!!
You can do it!!
Not sure this is what you were looking for, but I did a few choruses with the cleans and a lot of verb, then switched to the OD channel and had it (reverb) cut back a ways with the lead reverb control. If you want something else, just ask and I will give it my best shot. This clip also has the midboost on, (Which I only really like with a tele or Strat, this is with a LP) and much less gain than usual.dr. who wrote:Will you post a few clips showing the reverb on different settings with the clean and od respectively?
Emmys reverb clean and dirty: http://www.soundclick.com/player/single ... 23704&q=hi
VERY GOOD VERY GOOD!
That was what I was looking for. Thank Tag. I like the clean with verb a lot.
What are all those weird coiled wires and stuff?
tubedogsmith
that's an old technique that subs for sheilded wire. some early Mesa Boogies had this in them too. I think I've seen it in old radios or stereo equipment too.Structo wrote:What are all those weird coiled wires and stuff?
Yea, my early TwoRock Custom Prototype had them as well. My later production models did not. Both sounded great with verly little noise.tubedogsmith wrote:that's an old technique that subs for sheilded wire. some early Mesa Boogies had this in them too. I think I've seen it in old radios or stereo equipment too.Structo wrote:What are all those weird coiled wires and stuff?
I used to call the m bandaids.
Structo wrote:I used to call the m bandaids.
Maybe some guys should start using them again however. The amp is sitting here next to my computer and overhead fan, and is as quiet (more so?) than my Dumble was.
Glad it helped.dr. who wrote:That was what I was looking for. Thank Tag. I like the clean with verb a lot.
