There's a ton of space in here so I put the relays on the main board. It's a basic high plate HRM with reverb. I used an ECL86 as a reverb tube, and the orignal Peavey tank, which sounds great. The ECL86 is basically an EL84 and 1/2 12AX7. I used the pentode as a driver, triode for recovery. AT first I kept frying the tube socket with screen arcing, but I upped the screen resistor to 330K and all's good with the reverb.
To listen to it, click on my band's link below and start the jukebox at the top. Pretty poor recordings, just an ambient recorder sitting in front of the band in a loud bar. What guitar I'm playing is a crapshoot, I usually take 5-6 guitars to a gig, but the signal path is always clean, just volume pedal > wah > amp. Speakers are Emi Tonker and Swamp Thang, 16 ohms in parallel. Tubes vary as well, but I think I was running JJ KT-77's and JJ ECC83, in V1 and V2, Sovtek 12AX7LPS in the PI, Phillips ECL86 for reverb.
I typically set the eq to, T=10:00, M=2:00, B=2:00. Gain and drive on about 1:00 and volume at about 9:00. I often get the sound man complaining I'm not loud enough
Oh... and since the questions will come, here's the vocalist....
[img:640:480]http://www.sweettoothband.com/images/Nikki_M.jpg[/img]
