Jeff Beck Arredondo JCM800?
- moonlighter
I stumbled across these photos again after seeing them for years, but something stuck out to me this time that I had never noticed before. There appears to be what I'm assuming is an Arredondo modified 2203, likely Beck's knowing he used them (JCM800 Series) frequently. Unless it has some other mods, but the extra pot at the inputs would be typical for Arredondo.
Re: Jeff Beck Arredondo JCM800?
looks like a stock 80s 1959 or - more likely - 1987
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
- moonlighter
A Lead Series 1987 makes most sense, agreed.
But in the second photo we see it's not stock, there's a knob replacing one of the high inputs. This is common in Arredondo modded amps, but I'm curious if that is really the case here.
I don't see the knob. rather there may be two jacks? (or just one, which is angled possibly). Beck would often feed both channels with different signals. As you see in the ronnie scott video, he used the dark channel for wet sounds and the bright channel for dry sounds
4x12" w/H75s
4x12" w/H75s
- moonlighter
Zoomed in and sharpened. Still hard to tell, but it seems more apparent it's a second cable with a metallic shell.
new pic indicating dual input jacks https://www.facebook.com/photo/?fbid=10 ... 3039047483
4x12" w/H75s
4x12" w/H75s
- moonlighter
This is a great pic! Myth busted for certainRoe wrote: ↑Wed Dec 11, 2024 5:09 pm new pic indicating dual input jacks https://www.facebook.com/photo/?fbid=10 ... 3039047483![]()
I guess he used one input for wet signal (delay/reverb) and another for the dry tone, just like we know he did later at ronnie scotts.
4x12" w/H75s
4x12" w/H75s
