Hi,
I want to build an ODS with a built in Dumbleator. I did some search and I couldn't find any corresponding layout. It's pretty amazing how many layouts are available but none where the loop is included or maybe I did poor search job or something. If so please point to such a layout. Until then I have couple of questions:
In some schematics the Master is wired directly to the second triode stage in others it's after the OD relay. Considering that I want to make the loop to be switchable completely out of the circuit (via the foot switch with a DPDT relay) then where is the right place for the Master? Is it before the loop (and then the loop's output will act as a Master when engaged) or after the loop maybe hardwired to the PI input?
Thanks in advance.
						ODS with built in Dumbleator
Re: ODS with built in Dumbleator
Welcome to the Amp Garage.
I know a few members here have built the D'lator into the amp chassis.
I built a standalone loop.
But I found this layout in my files.
I do not know if it is correct so buyer beware.
				dcribbs1412
Might try external first see if you like or need it.
If so
Many have used Normster's layout for reference in the past
https://tubeamparchive.com/viewtopic.php?t=18797
Darin
						If so
Darin
Thanks for the quick replies! I'll check those out.
Normster loop
