ODS with built in Dumbleator
metalguy
Post by metalguy »
Hi,
I want to build an ODS with a built in Dumbleator. I did some search and I couldn't find any corresponding layout. It's pretty amazing how many layouts are available but none where the loop is included or maybe I did poor search job or something. If so please point to such a layout. Until then I have couple of questions:
In some schematics the Master is wired directly to the second triode stage in others it's after the OD relay. Considering that I want to make the loop to be switchable completely out of the circuit (via the foot switch with a DPDT relay) then where is the right place for the Master? Is it before the loop (and then the loop's output will act as a Master when engaged) or after the loop maybe hardwired to the PI input?
Thanks in advance.
Re: ODS with built in Dumbleator
Welcome to the Amp Garage.
I know a few members here have built the D'lator into the amp chassis.
I built a standalone loop.
But I found this layout in my files.
I do not know if it is correct so buyer beware.
dcribbs1412
Post by dcribbs1412 »
Might try external first see if you like or need it.
If so
Many have used Normster's layout for reference in the past
https://tubeamparchive.com/viewtopic.php?t=18797
Darin
metalguy
Post by metalguy »
Thanks for the quick replies! I'll check those out.
Normster loop
