Trouble shooting HRD
HRD had crackle and pop while on. Pulled the back. Changing tubes and had a spark from R61. Need to replace this one first. Spec says 1watt, 470 ohms. Question is is this a metal foil or carbon type? Best place to find replacement?
- Reeltarded
Re: Trouble shooting HRD
Changing tubes and it sparked? How?
Metal foil. I don't think there are any carbon comp resistors in a modern HRD.
while your at it reflow the joints on the power tube sockets, known to dry joint on a regular basis
For reeltarded
I was cleaning the tube sockets working on the crackle problem. Put the GT whites back in and turned on the amp. Spark came out of R61. Blew a hole in it! Planning on fixing R61 and replacing the power tubes as one was running very hot.
