Zener to trim 30v please
Hi
I have just fired up my 50w build and all is well apart from the B+. I have the MC 40-18029, line voltage 244v AC, 374-0-374 on the red secondary, so about 20v too high. B+ is 495v loaded. 493 on the plates of V4-5. Bias 30.5 mV.
I am adjusting the dropping string to get the B+3-5 down a little ( V1 pin 1 was 217v now 184v ) but I think I need to get a zener on the CT.
I have had a good look through Mouser but I am having trouble finding a suitable zener with the right power dissipation and reverse cathode.
I have a Mouser order going in soon so any help would be appreciated if you have used the zener method before.
						Re: Zener to trim 30v please
On a recent 100W build I used a couple of 1N5333 5W 3.3V Zener diodes in series on the CT to drop the voltage. I mounted them on a small PCB.
They do not get warm at all.
Regards,
Markus
Regards,
Markus
Thanks Markus, how about I order some of these:
http://uk.mouser.com/Search/ProductDeta ... 1N5347BRLG
10v 5W zeners and mount them say 3 in series to a little board then heatsink it to the chassis?
I'm used to old style (DO-3) through hole 50w 30v reverse zener diode by NTE.  Now days they have different style available.
http://www.mouser.com/ProductDetail/NTE ... tosHxdc%3d
Which you can find at Newark and other places. http://www.newark.com/jsp/displayProduc ... 90220|plid|
Mark, I was just emailing Mouser with that part number!
not available in my area WTF???????
I guess that 10V 5W Zeners should be able to dissipate the heat too. I have a tendency for overkill which is why I used 3.3V 5W Zeners.rogb wrote:Thanks Markus, how about I order some of these:
I completely forgot about using a panel mount Zener. The reason why I used the string of Zener diodes was that I wanted the flexibility to adjust the voltage depending on the number of zeners used.
Regards,
Markus
I used a 50w stud mount Zener on my little 6V6 Rocket.
The PT is from a organ and it was about 30v high.
Man, that thing gets pretty hot.
Don't skimp on the power rating!
I just heard from Leanne at Mouser and they won't ship NTE parts outside the US - no explanation.
I registered with Newark and went to pay the $27 for the part NTE5268AK but it said shipping would be added later with no indication of the cost so I cancelled that one for now.
Guess I will just have a high plate voltage for now, B3-5 on the PPS is good, though.
Sounds great too
Sounds great too
There's a couple of places (non-Mouser) I have bought high power stud mount zeners from, if you are having problems.  I have no idea why they wouldn't ship an NTE part to the UK.
These 2 places will have something you can use.
www.expediters.com
You need to have a part number to find things at Expediters.
http://www.surplussales.com/index.html
You can browse by type here.
www.expediters.com
Thanks I have contacted Surplus Sales for a shipping cost for 1x 50w 30v Zener. 1N3324RBrsi wrote:There's a couple of places (non-Mouser) I have bought high power stud mount zeners from, if you are having problems. I have no idea why they wouldn't ship an NTE part to the UK.
www.expediters.com
Thanks again
NTE currently doesn't have a UK distributor at the moment looks like, not sure if that has anything to do with it. You might want to try Farnell, I believe this is the cathode case equivalent to NTE5268AK.rogb wrote:I just heard from Leanne at Mouser and they won't ship NTE parts outside the US - no explanation.
http://uk.farnell.com/solid-state/1n332 ... tt=1n3324b
TM
Thanks TM, it needs an "R" to denote reverse polarity.ToneMerc wrote:NTE currently doesn't have a UK distributor at the moment looks like, not sure if that has anything to do with it. You might want to try Farnell, I believe this is the cathode case equivalent to NTE5268AK.rogb wrote:I just heard from Leanne at Mouser and they won't ship NTE parts outside the US - no explanation.
TM
I already looked at that from Farnell but they charge £16 ($25) shipping for one item if it is not UK stocked. plus $24 for the part
Hope to hear back from Surplus sales -$15 plus I hope a reasonable shipping charge.
Thanks Mark, I hope to go with the 50w stud zener as soon as I hear back from the surplus guys.
When this gets buttoned up I am starting on the Marshall 50w - gonna ABY the 2 50w amps
Weird, as it turns out, i have a 1N2824B sitting on my desk.
I think it's a 50W 33V stud mount zener.
If you strike out with Surplus Sales let me know.
