5e3 tubes reversed
mumford
5e3 tubes reversed
Post by mumford »
I recently converted an amp to 5e3 specs, except the inputs are a 12ax7 (two 6sf5s, actually) and the second stage and PI are a 6sl7. This is basically the opposite of a deluxe, which has the lower gain tube at the input. What performance change would I see if I switched them? It sounds ok, I'm just curious.
Cygnus X1
Re: 5e3 tubes reversed
Post by Cygnus X1 »
I've done it on the classic style 5E3 and wasn't satisfied with the results.
Turned fizzy, lost clarity.
Normal to have 12AY7 V1 and 12AX7 in V2.
mumford
Post by mumford »
Thanks! I'll try the old flip-a-dee-doo-dah.
mumford
Post by mumford »
Rewired it last night... WOW, what a change! Much brighter and cleaner, and overall just better. Now to track down my new V1 noise problem...
