Lower Voltage
jestaudio
Lower Voltage
Post by jestaudio »
Am i correct in assuming if you run lower voltages in a amp, say for example 260-0-260 rather than 290-0-290 you would end up with lower main output , i would also assume by adjusting the dropping string the preamp section would remain realtily unaffected
Firestorm
Re: Lower Voltage
Post by Firestorm »
True enough; output power is voltage dependent, but I doubt you could hear the difference between 260-0-260 and 290-0-290. Preamp gain, on the other hand, doesn't change much with voltage (unless the differences are huge), but preamp B+ does affect headroom, so if you want to preserve a particular sound, you would want to adjust the dropping string.
jestaudio
Re: Lower Voltage
Post by jestaudio »
Firestorm wrote:True enough; output power is voltage dependent, but I doubt you could hear the difference between 260-0-260 and 290-0-290. Preamp gain, on the other hand, doesn't change much with voltage (unless the differences are huge), but preamp B+ does affect headroom, so if you want to preserve a particular sound, you would want to adjust the dropping string.
Cheers i was pretty sure i was on the right track, to be honest the scheme i,m looking at uses a valve rec so i could easily use a diode rec to bring the voltage back up again
rogb
Re: Lower Voltage
Post by rogb »
I found in my AB763 that I needed to go to a 5U4GB to get any significant voltage drop so I had a low "browner" B+ and a higher "Super" one on the diodes.
My GZ34 is a Mullard and puts out nearly the same volts as the diodes :)
I use JJ 6V6s so no problems handling the power, the PT is also 200mA and could use 6L6s if needed.
Versatility, aint it great? 8) Thank you Leo, for such a killer amp design.
