Source for 2k, or 2k2 pots?
Anyone have a source for 2k2  cts or alpha pots?
						Re: Source for 2k, or 2k2 pots?
Why not just buy a bunch of 2K and measure them. Mine measure anywhere from 1.8 to 2.15butwhatif wrote:Anyone have a source for 2k2 cts or alpha pots?
Do you know of a source for cts or alpha 2k ?
I"ve got them from Mouser in the past.
That's strange, I could have sworn I have bought the 2K Alpha from AES before but now when I look, they don't seem to carry them.
On my last 100w build I got a NOS 2.5K Allen Bradley pot from Apex Jr.
- glasman
You can always take the back off and scrape the pot up to the value you need.   A couple hundred ohms is pretty easy
Gary
									Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
I tried searching Mouser and couldn't find them.  They do have them though...
http://www.mouser.com/ProductDetail/Alp ... FxcQzTA%3d
Deric®
I use 5K pots then put a resistor in parallel in parallel. Works fine as the pot is linear taper. Then I can get an "custom" resistance I want. High resistance just means "duller" tone in regards to presence though.
						- David Root
I have a source for NOS Centralab 2K5 pots. They have about a 3" brass shaft which would have to be cut down. They are PCB mount type but could be used panel mount style, see pic.
I bought two, they are marked 2K but are nearer 2.5K. One is 2.50K, the other is 2.38.
Mouser has thembutwhatif wrote:Do you know of a source for cts or alpha 2k ?
http://www.mouser.com/Search/ProductDet ... Lvhb%2bg==
Thanks for the info   I was able to find nos  at--
http://www.surplussales.com/Potentiomet ... ted-4.html
Also they have a couple dozen knobs-very similar to the first dumble combo
type part # (KNB) PKS1106B1/4
http://www.surplussales.com/ShaftHardware/Knobs-6.html
