#183 voltages
Re: #183 voltages
As stated in previous posts, there is something wrong with your screen voltages. pin 4 on the power tubes.
						Re: #183 voltages
I actually have another choke floating around somewhere. Might be worth to give it a go. ThanksCHIP wrote:As stated in previous posts, there is something wrong with your screen voltages. pin 4 on the power tubes.
Re: #183 voltages
Having plate voltages at v1, v2 and v3, suggests you choke is working. Imo you should double check the wiring from the filtering board to your screen(pin4) voltages at the power tubes as other mentioned before.lionaird wrote:I actually have another choke floating around somewhere. Might be worth to give it a go. ThanksCHIP wrote:As stated in previous posts, there is something wrong with your screen voltages. pin 4 on the power tubes.
See the schematic with outlined red markings.
						Re: #183 voltages
Ditto, hard to tell from my handheld screen, but it appears the screen termination on pwr board is wired to the wrong location.erwin_ve wrote:Having plate voltages at v1, v2 and v3, suggests you choke is working. Imo you should double check the wiring from the filtering board to your screen(pin4) voltages at the power tubes as other mentioned before.lionaird wrote:I actually have another choke floating around somewhere. Might be worth to give it a go. ThanksCHIP wrote:As stated in previous posts, there is something wrong with your screen voltages. pin 4 on the power tubes.
TM
Re: #183 voltages
From what I can see he has it wired correctly. A red wire is coming from the power board to pin 6,ToneMerc wrote:Ditto, hard to tell from my handheld screen, but it appears the screen termination on pwr board is wired to the wrong location.erwin_ve wrote:Having plate voltages at v1, v2 and v3, suggests you choke is working. Imo you should double check the wiring from the filtering board to your screen(pin4) voltages at the power tubes as other mentioned before.lionaird wrote: I actually have another choke floating around somewhere. Might be worth to give it a go. Thanks
TM
which then he used green wires to connect the others.
Re: #183 voltages
Ok. Checked all the connections from/to the power PCB and all seems to be wired correctly. Including B+2 out to pin 6. Very weird
						Re: #183 voltages
What voltage reading do you have at B2?lionaird wrote:Ok. Checked all the connections from/to the power PCB and all seems to be wired correctly. Including B+2 out to pin 6. Very weird
I ask this specific because in all the voltage readings you didn't mention B+2. If you have the right voltage there; the wire to the screens might be broken. If you don't have a voltage there something is not wired correctly at the filter board.
Re: #183 voltages
My B+2 voltage reading is 508 Volts. I get the same reading on pin 6erwin_ve wrote:What voltage reading do you have at B2?lionaird wrote:Ok. Checked all the connections from/to the power PCB and all seems to be wired correctly. Including B+2 out to pin 6. Very weird
Re: #183 voltages
And what are the screen resitors readings, between pin 4 and 6, in Ohms with the amp off?lionaird wrote:My B+2 voltage reading is 508 Volts. I get the same reading on pin 6erwin_ve wrote:What voltage reading do you have at B2?lionaird wrote:Ok. Checked all the connections from/to the power PCB and all seems to be wired correctly. Including B+2 out to pin 6. Very weird
Re: #183 voltages
What power transformer are you using looks to have dual B+ secondary’s.
If so use the red/red not the red with the white stripe.
You want 465 volts B+.
Re: #183 voltages
erwin_ve wrote:lionaird wrote:Hmm, can't get any ohm reading when measuring the screen resistors at any of the power tubeserwin_ve wrote: And what are the screen resitors readings, between pin 4 and 6, in Ohms with the amp off?![]()
Yes, that's correct. I'm using the 345-345 secondaries. Same as in the schematics of the Ceriatone clone. So I should use the 320-320 secondaries to tame the voltage a bit?What power transformer are you using looks to have dual B+ secondary’s.
You want 465 volts B+.[/code]
Re: #183 voltages
How very bizarre. All 4 screen resistors didn't work. I replaced them with new ones and suddenly the beast comes to life
Voltages again.
B+: 491V
B+2: 488V
B+3: 462V
B+4: 336V
B+5: 328V
V1
1: 197.5V
3: 1.890V
6: 198.6V
8: 1.9V
V2
1: 196.5V
3: 1.695V
6: 203V
8: 1.963V
V3
1: 321V
2: 39V
3: 62V
6: 326V
7: 38V
V4
3: 489V
4: 479V
5: -45.5V
6: 488V
V5
3: 488V
4: 480V
5: -45.5V
6: 487V
V6
3: 489V
4: 480V
5: -44.8V
6: 487V
V7
3: 488V
4: 479V
5: -44.9V
6: 487V
						Voltages again.
B+: 491V
B+2: 488V
B+3: 462V
B+4: 336V
B+5: 328V
V1
1: 197.5V
3: 1.890V
6: 198.6V
8: 1.9V
V2
1: 196.5V
3: 1.695V
6: 203V
8: 1.963V
V3
1: 321V
2: 39V
3: 62V
6: 326V
7: 38V
V4
3: 489V
4: 479V
5: -45.5V
6: 488V
V5
3: 488V
4: 480V
5: -45.5V
6: 487V
V6
3: 489V
4: 480V
5: -44.8V
6: 487V
V7
3: 488V
4: 479V
5: -44.9V
6: 487V
Re: #183 voltages
I think that would be a good idea. If you haven't done so already, I would also put the 1R current sensing resistors back in so you can easily check the idle current.lionaird wrote:I'm using the 345-345 secondaries. Same as in the schematics of the Ceriatone clone. So I should use the 320-320 secondaries to tame the voltage a bit?
Re: #183 voltages
Ok, using the 640V secondaries now which brings B+ down to 450V. Don't really need the 1R resistors because my bias meter shows idle current and dissipation wattages. I adjusted the idle current to around 40mA which gives me a dissipation wattage of 18 Watts...martin manning wrote:I think that would be a good idea. If you haven't done so already, I would also put the 1R current sensing resistors back in so you can easily check the idle current.lionaird wrote:I'm using the 345-345 secondaries. Same as in the schematics of the Ceriatone clone. So I should use the 320-320 secondaries to tame the voltage a bit?
Everything is working now. Apart from the LED of the 50/100 switch. The switch doesn't really seem to do anything either. I measured it and it take pin 1/8 of V4 and V7 off ground. Doesn't really seem to reduce the output wattage though...
Re: #183 voltages
When wirewound resistors have a big current to swallow they sometimes act like a fuse. Seems that has happened. Question is why was there a big current?lionaird wrote:How very bizarre. All 4 screen resistors didn't work. I replaced them with new ones and suddenly the beast comes to life![]()
Voltages again.
B+: 491V
B+2: 488V
B+3: 462V
B+4: 336V
B+5: 328V
V1
1: 197.5V
3: 1.890V
6: 198.6V
8: 1.9V
V2
1: 196.5V
3: 1.695V
6: 203V
8: 1.963V
V3
1: 321V
2: 39V
3: 62V
6: 326V
7: 38V
V4
3: 489V
4: 479V
5: -45.5V
6: 488V
V5
3: 488V
4: 480V
5: -45.5V
6:
V6
3: 489V
4: 480V
5: -44.8V
6: 487V
V7
3: 488V
4: 479V
5: -44.9V
6: 487V
