#183 voltages
CHIP
Re: #183 voltages
Post by CHIP »
As stated in previous posts, there is something wrong with your screen voltages. pin 4 on the power tubes.
lionaird
Re: #183 voltages
Post by lionaird »
CHIP wrote:As stated in previous posts, there is something wrong with your screen voltages. pin 4 on the power tubes.
I actually have another choke floating around somewhere. Might be worth to give it a go. Thanks
erwin_ve
Re: #183 voltages
Post by erwin_ve »
Having plate voltages at v1, v2 and v3, suggests you choke is working. Imo you should double check the wiring from the filtering board to your screen(pin4) voltages at the power tubes as other mentioned before.
See the schematic with outlined red markings.
ToneMerc
Re: #183 voltages
Post by ToneMerc »
Ditto, hard to tell from my handheld screen, but it appears the screen termination on pwr board is wired to the wrong location.
TM
CHIP
Re: #183 voltages
Post by CHIP »
ToneMerc wrote:
erwin_ve wrote:
lionaird wrote: I actually have another choke floating around somewhere. Might be worth to give it a go. Thanks
TM
From what I can see he has it wired correctly. A red wire is coming from the power board to pin 6,
which then he used green wires to connect the others.
lionaird
Re: #183 voltages
Post by lionaird »
Ok. Checked all the connections from/to the power PCB and all seems to be wired correctly. Including B+2 out to pin 6. Very weird
erwin_ve
Re: #183 voltages
Post by erwin_ve »
lionaird wrote:Ok. Checked all the connections from/to the power PCB and all seems to be wired correctly. Including B+2 out to pin 6. Very weird
What voltage reading do you have at B2?
I ask this specific because in all the voltage readings you didn't mention B+2. If you have the right voltage there; the wire to the screens might be broken. If you don't have a voltage there something is not wired correctly at the filter board.
lionaird
Re: #183 voltages
Post by lionaird »
My B+2 voltage reading is 508 Volts. I get the same reading on pin 6
erwin_ve
Re: #183 voltages
Post by erwin_ve »
And what are the screen resitors readings, between pin 4 and 6, in Ohms with the amp off?
67plexi
Re: #183 voltages
Post by 67plexi »
What power transformer are you using looks to have dual B+ secondary’s.
If so use the red/red not the red with the white stripe.
You want 465 volts B+.
lionaird
Re: #183 voltages
Post by lionaird »
erwin_ve wrote:
lionaird wrote:
erwin_ve wrote: And what are the screen resitors readings, between pin 4 and 6, in Ohms with the amp off?
Hmm, can't get any ohm reading when measuring the screen resistors at any of the power tubes :shock:
You want 465 volts B+.[/code]
Yes, that's correct. I'm using the 345-345 secondaries. Same as in the schematics of the Ceriatone clone. So I should use the 320-320 secondaries to tame the voltage a bit?
lionaird
Re: #183 voltages
Post by lionaird »
How very bizarre. All 4 screen resistors didn't work. I replaced them with new ones and suddenly the beast comes to life :D
Voltages again.
B+: 491V
B+2: 488V
B+3: 462V
B+4: 336V
B+5: 328V
V1
1: 197.5V
3: 1.890V
6: 198.6V
8: 1.9V
V2
1: 196.5V
3: 1.695V
6: 203V
8: 1.963V
V3
1: 321V
2: 39V
3: 62V
6: 326V
7: 38V
V4
3: 489V
4: 479V
5: -45.5V
6: 488V
V5
3: 488V
4: 480V
5: -45.5V
6: 487V
V6
3: 489V
4: 480V
5: -44.8V
6: 487V
V7
3: 488V
4: 479V
5: -44.9V
6: 487V
Re: #183 voltages
lionaird wrote:I'm using the 345-345 secondaries. Same as in the schematics of the Ceriatone clone. So I should use the 320-320 secondaries to tame the voltage a bit?
I think that would be a good idea. If you haven't done so already, I would also put the 1R current sensing resistors back in so you can easily check the idle current.
lionaird
Re: #183 voltages
Post by lionaird »
Ok, using the 640V secondaries now which brings B+ down to 450V. Don't really need the 1R resistors because my bias meter shows idle current and dissipation wattages. I adjusted the idle current to around 40mA which gives me a dissipation wattage of 18 Watts...
Everything is working now. Apart from the LED of the 50/100 switch. The switch doesn't really seem to do anything either. I measured it and it take pin 1/8 of V4 and V7 off ground. Doesn't really seem to reduce the output wattage though...
erwin_ve
Re: #183 voltages
Post by erwin_ve »
lionaird wrote:How very bizarre. All 4 screen resistors didn't work. I replaced them with new ones and suddenly the beast comes to life :D
Voltages again.
B+: 491V
B+2: 488V
B+3: 462V
B+4: 336V
B+5: 328V
V1
1: 197.5V
3: 1.890V
6: 198.6V
8: 1.9V
V2
1: 196.5V
3: 1.695V
6: 203V
8: 1.963V
V3
1: 321V
2: 39V
3: 62V
6: 326V
7: 38V
V4
3: 489V
4: 479V
5: -45.5V
6: 488V
V5
3: 488V
4: 480V
5: -45.5V
6:
V6
3: 489V
4: 480V
5: -44.8V
6: 487V
V7
3: 488V
4: 479V
5: -44.9V
6: 487V
When wirewound resistors have a big current to swallow they sometimes act like a fuse. Seems that has happened. Question is why was there a big current?
