Liverpool Started,Guestion
Re: Liverpool Started,Guestion
Well, don't shut it off!  Just keep playing forever.
Mikey - Either what Jana said - sound advice.
Or...
Try disconnecting the MOV. I don't usually use them.
If it still blows fuses I would replace the switches.
Might be drawing a sizeable arc / shorting.
Does it blow when the Standby or Power switch is turned off?
Some of the gurus might have some better understanding.
Mine usually blow when I turn on, especially if they aren't slow blow - for mains power I use slow blow rated 40/50% higher than the actual current draw.
Good Luck,
Bob
									Or...
Good Luck,
Bob
Why Aye Man
						TW
Thank You,Ill try that today,I want to get the TRIO happy and healthy and then a real utuber!!!!!!The express has a nos set of 6v6 coming.There all in head cabs ready for Hollyweird!!!
Liverpool
OK,Thank You Bob,I pulled the MOV and she"s playing steady,I really like the liverpool.It may be my favorite.Its more like the express,After 5 it just screaming,More power than you will ever need,Anyway it was well worth the time and cash to build this amp.Just a few days away from getting everbody here some sounds,Thank again everybody for all the help and rj for the amp parts,Mikey
