Any interest in seeing some Dumble Tweed Deluxe photos?
				Charlie Wilson
Re: Any interest in seeing some Dumble Tweed Deluxe photos?
Hello, it doesn't look like the pots have a ground. They should share a ground with the 33uf preamp filter and the PI cathode bypass cap.
Good catch Charlie! I'll update according.Charlie Wilson wrote:Hello, it doesn't look like the pots have a ground. They should share a ground with the 33uf preamp filter and the PI cathode bypass cap.
Personally I would ground the Plate and Screen PS caps further upstream from the preamp..The ideal spot would be at the transformer bolts..I don't care how Dumble did it.
I agree, I set my board up with segregated grounds.talbany wrote:Personally I would ground the Plate and Screen PS caps further upstream from the preamp..An ideal spot would be at the transformer bolts.. I don't really care how Dumble did it..
TM
I separated grounds in this one too. Made quite a difference. Sounds great and is very quiet.
Very nice! What PT/voltages did you use Jelle?jelle wrote:I separated grounds in this one too. Made quite a difference. Sounds great and is very quiet.
The one in the pic has a Weber chassis and PT. From memory, I believe 380v.
Nice. You running a 5Y3GT so far? I have a 5E3 build in progress with a 380VAC PT as well that started as a modded circuit, but now I'm thinking about building out into a Tweedle D. I haven't built the board yet so the door is still open.jelle wrote:The one in the pic has a Weber chassis and PT. From memory, I believe 380v.
Thanks for the nice comments! Yes, that is the rectifier I used.
Also, the one I posted is another Tweed Deluxe mod, not the Tweedly-D.
Yeah, I figured it was different as the PI and a few other things look different. Great looking amp though, very clean (as usual)jelle wrote:Thanks for the nice comments! Yes, that is the rectifier I used.
Thanks to Charlie and all the guys for the information.
Got my board built and populated. chassis components mounted. Had a Classictone OT but no PT so will get that ordered.
Need to get a 10k trimmer too.
Thanks - now correctedToneMerc wrote:V1 cathode caps should have the ground node in the center of both caps with the cathode leads exiting north and south,rogb wrote:Board layout from TM and Charlie's work - 2nd draft so please check
TM
Layout updated/cleaned up. Posted on page 9
Nice looking layout.
Is this layout showing a brass plate for grounding?
I'm not going that route so my grounding will be different.
I gots some trannies guess I need too bend up  a tweed chassis.I wanna be cool like you guys
