Fuse for DMM
C Moore
Fuse for DMM
Post by C Moore »
I have a Amprobe 35XP-A that needs a fuse. It takes a 2A 1000V. I called Ace Hardawre and Radio Shack, they do not carry any fuses over 250 volts. Test Path has them at $5.00 for a 2 pack, plus $10.00 for shipping. So it is about 15 bux for 2 fuses.
Where do you guys get a fuse like that when you need it?
Thank You
selloutrr
Re: Fuse for DMM
Post by selloutrr »
mouser
digikey
newark
allied
shipping is usually based on a flat rate up to a certain weight or size. try combining the fuses into a purchase with other parts to get more for your $ or maybe just more fuses :wink: .
My Daughter Build Stone Henge
Re: Fuse for DMM
Try local Residentual Electrical Wholesale distributor or Grainger if you have one. They all carry replacement DMM fuses.
C Moore
Re: Fuse for DMM
Post by C Moore »
selloutrr wrote:mouser
digikey
newark
allied
Yeah right. Thanks for nothing.
Half of the stuff I have now is because I needed a resistor I did not have, or some other part that cost $3.00. So to get those single items I "combined" the order with a bunch of other things, just to make myself feel better. :oops:
Re: Fuse for DMM
I think Mark Fowler is on the right track. Your local electrical supply house might be a good source, places like Tri-State Electric. I don't know what you've got in your neck of the woods. Maybe call up an electrical contractor and ask for a suggestion. You might be surprised what you find out.
It won't be cheap, but there won't be any shipping charge. We all go through this with the shipping. The days of going down to the corner store to buy anything are long gone.
Re: Fuse for DMM
My wife works at a Electric Wholesale place and that is why I know they stock things like the DMM fuses.
Any supply house that supplies electrical products to the electricians and HVAC guys.
C Moore
Re: Fuse for DMM
Post by C Moore »
More good suggestions and info. Thank You
selloutrr
Re: Fuse for DMM
Post by selloutrr »
Your welcome for nothing! here is another one...
if you had a fluke they would send you one for free :wink:
David Root
I have a Fluke 187
Post by David Root »
Now he tells me!
C Moore
Re: Fuse for DMM
Post by C Moore »
selloutrr wrote:Your welcome for nothing! here is another one...
Is this hitting below the belt?
Can I get a ruling from the judges please?
It's funny you should say Fluke, that is how I found out I snapped the fuse in my Amprobe. I was using the Fluke as a volt meter and the Amprobe as an amp meter. I put 10 volts across a 100 ohm resistor, but I did not read any current. So I reversed the duty of the meters. The Amprobe showed 10 volts OK and the Fluke read 100MA.
I thought there was something wrong with the Amprobe. I did not know some of the meter functions would still operate, even with a bad fuse. This is the first time I lost a fuse in a meter. I just ASSUMED if the fuse was bad that the meter would not work. But I was wrong.
Thanks again for all the help. TAG has been good to me, and I appreciate it.
Thank You
Re: Fuse for DMM
Perhaps it was your response to his post trying to help you.
Emotions are hard to translate on a keyboard and if a sarcastic answer is given it helps if you put a smiley by it so the person knows you're kidding.
Just sayin'.
C Moore
Re: Fuse for DMM
Post by C Moore »
Structo wrote:Perhaps it was your response to his post trying to help you.
Just sayin'.
Good Heavens, I know he was kidding, and I did put a embarrassed smiley on my post. Then I said "Thank You" 3 times in response to his free fuse from Fluke comment. It has all been said with respect and good humor as far as I am concerned.
selloutrr
Re: Fuse for DMM
Post by selloutrr »
EVERYONE CALM DOWN!!!!
it's all good no need to get the irons hot
no one is fighting, no feeling got hurt...
everyone is sorry...
deep breathe in ... thats good now out...
good job... now count to ten...
don't you feel better. :)
just a thought sears might be able to order you a fuse you can pickup at the store.
Re: Fuse for DMM
OK, I'm OK your OK. :lol:
Sonny ReVerb
Re: Fuse for DMM
Post by Sonny ReVerb »
You guys are drinking too much coffee ;) [That's a big wink, wink!!]
