Want to build a 3 watt amp
nee
Post by nee »
Greetings!
I have the opportunity of getting some 3W output transformers and am wondering what might be a good project for a bedroom amp?
To put it simply: can I use - for example - a classic Fender preamp and stick the 3W transformer plus tube on the end of it, or is there more to it than that?! :?
Is it possible to use something like a 6V6GT with this trani, or should I be looking at a lower-power tube? What happens if you use a high-power tube with a low-power trani?
Many thanks!
IanG
flood
Re: Want to build a 3 watt amp
Post by flood »
a 6V6 will push a healthy 5W. you could look at the ECL82 which would give your roughly 3W at 250V plate voltage. it also saves you a triode stage, since it contains a triode and pentode in one envelope. add one 12AX7 to that and you could hit wreck territory at low volumes :D
also check out my 4W wreck thread here: https://tubeamparchive.com/viewtopic.php?t=9423
In the interest of full disclosure, I am Animal Factory Amplification.
You don't say if the transformers are single ended or push pull or what the primary and secondary loads are rated for. All this makes a difference in making a suggestion. What else do you know about what you have?
Ripthorn
Post by Ripthorn »
5902 submini's put out about 1W each (~2W in push pull) and I quite like them, though they are low plate voltage tubes (160V max).
Exact science is not an exact science
nee
Post by nee »
The transformer is single-ended, 4 Ohms-5K, 8 Ohms-8K, 16 Ohms-10K.
IanG
See if you can find an EL95.
flood
Post by flood »
Phil_S wrote:See if you can find an EL95.
have you used one? how do they sound? i can't wait to get started on my build (see link above), but haven't seen much info on EL95s in guitar amps.
