Hi,
I'm going to build a 2x12'' cab with two red,white and blues in it. Anyone has d*mble or suitable drawings for couple of 12'' ?
cheers,
2 x 12'' cab drawings
- skyboltone
Alexander's open back cabinet research unrevealed.
Take a close look at this cabinet. I have looked everywhere for the dimensions of that hole because I built that exact cabinet a long time ago. I never throw anything away but I can't find the drawing Howard gave me. That's an Altec 417-8H in there. I've got an -8C here and it measures 12.125 inches in diameter. You should be able to estimate something close, double it and make it vertical and have a nice open back set. Lets take a stab at it. I think you draw two 9" circles whose centers are 5.75" apart and cut them together. Something like that. Double the square inches for the twin.
[IMG:658:600]http://i4.tinypic.com/15iaq08.jpg[/img]
I sure like that pedal. I'm gonna build one just like it.
Good Luck and thank Rob Livesey for the pictures
Dan
Dan
Re: 2 x 12'' cab drawings
12 x 20 3/4 x 26 1/2 are external dimensions. The hole in the back panel is 7 x 14 with a 3.5 inch radius at each end.
Pictured below is actually a Two Rock cab copy of a Dumble cab. With Tone Tubby speakers and a MKIIC+ head.
[img:375:500]http://home.comcast.net/~908ssp/DSCN1074copy.jpg[/img]
Alex
TheCageWreck and Glaswerks SOD100
Hey, that amp looks alot like mine! What an odd coincidence.
The specs I used are:
Cab = 20" High x 10 1/4" Deep x 20 3/4" Wide
Rear baffle = 16" high
Oval = 11.5" x 9"
For cab dimensions for a 2 x 12", check out a two rock 2 x 12.
Edit: Looks like you already got it.
Oval = 11.5" x 9"
Hello,
Thanks alot to everyone
Now it will be easy to start building.
Btw. anyone has Eminence 'red,white and blues' + Eminence 'The Tonker' in a same cab ?
cheers,
cheers,
mat
- skyboltone
Normster, are you talking about the separator between the chassis and the speaker enclosure as the rear baffle?Normster wrote:Hey, that amp looks alot like mine! What an odd coincidence.![]()
Oval = 11.5" x 9"
Baffled in Sausalito
Dan
No, actually those are my combo dimensions in case Mat wanted to build a cab the same size. Sorry, that was kind of confusing.
BTW, pretty similar, eh?
[img:640:480]http://bad-domain/DumbleRepro/DSC01923.JPG[/img]
