flood wrote:hey colossal,
thanks for the VERY useful information... i didn't know about that problem at all.
i'm looking at the option of scaling the power amp and the PI only, leaving the preamp tubes at the higher voltage. would i still need the additional measures? couldn't hurt to integrate them, i suppose.
Hi Flood,
You're welcome but don't thank me, thank Dana (UR12) as he did all of the hard work!
If you are just planning to scale the power section here is an excerpt from Dana's manual which is of immediate use for your application:
"<b>Regulating the Power Tubes Only</b>
This method is preferred by some, just like regulating the whole amp is preferred by others. This method will split the power supply into 2 different parts. One part is regulated, which supplies voltage to the power tube plates and screens, and the other part is left normal to run the preamp tubes. This method will also require you to make an additional mod to the amp. You will need to add a Master Volume so that the signal coming from the preamp tubes running at normal voltages won’t overdrive the power tubes running at reduce voltages. The general consensus is to add a Post Phase Inverter Master volume or PPIMV. This works well in a Push Pull amp but there is no Phase Inverter in a Single Ended amp and a normal Master Volume control will work fine between the last preamp stage and the power tube(s). You will also need to install 2 1N4007 diodes to isolate the two different sections of the power supply so they don’t interact with each other"
-- D. Hall, VVR2 Installation Manual
I've attached some drawings from the manual which should help you visualize what you would need for this installation.
FWIW, the amp that I installed a VVR in (a 6V6 plexi), I scaled the whole amp. I also added a PPIMV just to see how the tone would be affected. I found the VVR to be very useful as a means to control the overall sound pressure while preserving the essence of the amp's tone up to a point. This is what it was intended for...controlling stage volume, not getting perfect tone down to bedroom levels. It does exactly what it is supposed to. Even with the VVR, I still played the amp loud to get to the sweet spot. The VVR took the edge off. I did not however care for the master volume or the effect it had on the amp. A master volume however is necessary if you are scaling the power amp only as you will be slamming the PI if you turn down the voltage to the power section without limiting the signal going to the PI from the preamp.
flood wrote:re: the amp - i plugged it in and let loose and it worked pretty well on both channels. i do have a weird feeling that the power output is a bit lower than expected though, but then i am getting only about 300V on the EL84 plates, as opposed to the 350 recommended in the schematic.
Yes, lower voltage would change the tone. You might want to check your rectified voltage to make sure the PT is putting out what you expect.
flood wrote:there is one rather nasty problem though: i included a cascade switch. this is essentially a 3PDT wired to:
1. route the output from the lead channels 1M volume resistor into the bass channel via a 220k resistor while
2. disconnecting the bass input jacks and
3. shorting the lead channel's 220k cathode follower mixer resistor, input side, to ground.
The added complexity of this arrangement may have some tradeoff in terms of overall quality. I tried a similar switching arrangement which allowed the amp to run in either parallel or cascade but was only using one input jack. I ran into issues with noise although I was very careful with lead dress and shielding. I think the additional lengths of wire running from the tube socket routing signal were not a good idea and contributed to the problem. I also ran into oscillation problems with mixing the channels. Although I was able to work out the issues, I eventually scrapped the idea as it was more problematic than it was worth. For what it is worth, I just built a JCM800 style amp that is set up correctly as a cascaded amp and it is way, way quieter than the other amp using the cascade/parallel switch, has none of the oscillation problems, and sounds just way more massive. It is like a very mean, musical chainsaw
flood wrote:the distortion sounds fizzy, gated and almost synth-like. it's very hard to describe. almost like a tame version of the infamous metasonix f***ing f***er. there seems too be some clean signal bleeding through as well. will try and record it for you guys. It could be lead dress or the fact that there is no shunt resistor to ground to act as a voltage divider between the cascaded channels. not sure; will have to troubleshoot that. but not tonight. no more tonight
It would help to see a picture of how you have the switch set up. It sounds like something strange is going on. The distortion tone will depend too on how the tubes are biased and cathode bypassed but the gated quality sounds a bit odd. With the setup I used, the Bright channel volume knob became a Gain control when the amp was in cascade mode so there was some signal shunted to ground.
Good luck sorting it out. In the meantime you might want to take the switch out of the equation, making sure the amp sounds good in one mode or the other. If you can get that going, then that will help you troubleshoot where things could be going wrong.
