http://www.piher-nacesa.com/pdf/14-PT15v03.pdf
how would i connect this type trim pot. its one with two wiper pins. 4 all together.
						trim pot
- VacuumVoodoo
Re: trim pot
Use just one of the wiper pins. It's electrically just one but doubled to provide for stable mechanical mounting of the trimpot on a PCB.
									Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
Re: trim pot
thats what i thought. so the two 10uf caps + side goes to the one wiper pin then to ground and the 47k would go to the trace then the otherside of the trace goes to ground. on this piher pot the trace is the two pins that go out to  the side and bend down, the wiper would be the pins on the bottom. i hope.
						- VacuumVoodoo
Re: trim pot
You are talking about the trimpot in the lower left  in the datasheet, right?
The two pins/solder lugs that are part of the central metal ring are the wiper.
Aleksander Niemand
Zagray!-review
Zagray!-review
Re: trim pot
yes thats the one. i ordered a bunch of them. i always get cunfused by the extra pins, actually the back can be treated as one pin.
						Re: trim pot
heres a jpg of what i plan to do. i hope this picture comes in ok.
						- VacuumVoodoo
Re: trim pot
That is correct.
									Aleksander Niemand
Zagray!-review
Zagray!-review
