Alessandro Pots
				aclempoppi
Alessandro Pots
Wondering about trying these in Blackface amps and Strat. If these are the same Canadian PEC pots used in Bad Cat amps, they seem to be too large for the sloped  front of the fender chassis, don't know. But for the Strat , that may not be an issue. Biilyz posted in another topic, that he used them in a Nocaster. So maybe he can shed some light on the subject. Any way, if you folks have any experience with these pots, I would appreciate your opinions.   Thanks  Art
									None of Us is Free, if One of Us is Chained
						Re: Alessandro Pots
The Allesandro pots for guitar are of a smaller diameter to fit the guitar cavity. You can solder to the back as well.  Also, He has some made with splined split shafts for the strat or Gibson guitars.  The Solid shafts are fine for Telecasters.  They are made for him by PEC in Canada.  The regular PEC pots are good amplifiers, but I have not tried to fit them in a Fender or any other amp. I only use them in my custom builds.
I contacted PEC about some special pots and they will do them, but the cost is high. So Allesandro's are no more expensive. I get them from Ce Electronics , who are also now carrying the PEC pots too, at $7.95 ea.
				hitchcaster
Re: Alessandro Pots
his amp pots are a little different then the standard PEC's.. i like the standard  PEC's better and they are cheaper.. and yeah, the guitar pots are 1/2w and custom for him.  i like jim wagner pots better for guitars.   thats all IMHO.
				aclempoppi
alessandro pots
Thanks for your info you guys! Billyz I'll check out CE electronics. What kind of pickups are you installing in your custom guitars? I just have mid level Lindy Fralins Vintage pickups in my '89 Am Std Strat, but they seem to get the job done. Hey, Hitchcaster, have you tried the PEC pots in any Fender amps? Never heard about Jim Wagner pots, I'd appreciate any info and experience you might have to offer about these.  Thanks Art
						Re: Alessandro Pots
My local electronics house has PEC pots packaged by NTE.
Those are some nice pots for sure. Sealed and seem really well made.
But my guy charges $10 each for them......
Re: Alessandro Pots
I was at Fry's recently and they sell the NTE PECs for $6.95. They were all linear though.
						Re: Alessandro Pots
For some strange reason Linear PEC pots are cheaper than Audio.  I buy all the pots I can get Fry's to stock, in Linear that is. I have never seen 1 meg audio there though.  The Jim Wagner WCR pots are CTS I believe, selected as they vary quite a bit in value.  I was at Collings guitar factory and they were sorting all the CTS pots for value. And then using them to compensate for Bright or Dark sounding guitars. Higher values went into the Dark ones lower value into the bright ones.
the Alessandro Guitar pot are are rated for 1 W not 2 W as the Regular PEC's are. Hence the smaller diameter to fit into more guitar cavities.
Re: Alessandro Pots
You are right, the ones at my store are all linear.
Re: Alessandro Pots
When did Bad Cat start using PECs?
						Re: Alessandro Pots
Anyone have a URL for CE Electronics?
						Re: Alessandro Pots
Re: Alessandro Pots
One could use a tax ID, yes?Structo wrote:https://secure.cedist.com/
I suppose you know that you have to be a dealer to buy from there.
"A man with an experience is never at the mercy of a man with an argument." Hilmar von Campe
						Re: Alessandro Pots
I just got a bunch of audio taper PECs. I'm not crazy about how it feels when you turn it. It feels kinda rough. The Bourns pot I've tried feel better when you turn it. How are the PECs that you guys have used?
I've tried some surplus PEC equivalents and those are very smooth.
Re: Alessandro Pots
THe PEC pots I have used feel a bit stiff to turn.
Re: Alessandro Pots
Maybe that's just the way they are? I was thinking maybe I got a bad batch or something. I was all excited about getting them cuz I really liked the feel of the surplus pots I got. Was hoping the same for these PECs.
