D lator ?
zimm
D lator ?
Post by zimm »
Hi all, I just finished putting together a d-lator. Im having a weird issue. If I have the amp master volume low and the d-lator hooked up I get little to no amp output. If I increase the MV to 12 oclock, all of the sudden I get output, the d-lator responds as it should, amp sounds great. I guess my question- is this normal? Is there a certain level that the dlator needs in order to pass the signal? Seems odd to me. My voltages seem good. I am unable to pinpoint a faulty component because when I get the no output condition and touch certain areas with my VOM probe the signal suddenly pops on and the output is then normal, until I turn it off for a while and turn it back on, then Im back to no output. I rebuilt both boards, replaced components, retouched connections... Im stumped. I guess a pic would help, Ill try to post one tonight.
Re: D lator ?
That's because the master is before the loop.
zimm
Re: D lator ?
Post by zimm »
It just seems odd that it goes from nothing to all the sudden popping on. There is no smooth volume transition as I increase the MV. Just nothing, then MV hits ~noon and, BAM, volume. Also, the amp is a BM HRM circuit if that helps.
moj067
Re: D lator ?
Post by moj067 »
That might be a cable issue what w/ running in and out of pre out mains in then to effects. If you unity at 12:00 on the D-lator gets you nothing def. something is up.
Post pix if cables and connections are fine.
