Hi everyone,
  My build is progressing well.. Now I am ready to install the stackpole impedence switch, but no matter how much I tighten the nut, the switch will loosen up dans rotate with the knob..
  Did you guys use the anti-rotation tab on the switch, or you just chopped it off?.. That's what I am thinking of doing, but maybe there is a better way to lock the switch in place without cutting the tab...
  Thanks!!
  Hugues
						How to prevent rotation of impedance switch?
Re: How to prevent rotation of impedance switch?
I had one of those type switches in an amp and I drilled a small hole for the tab.
On another amp I used the switch from Hoffman and used a star washer and don't have any issues.
Chopped it off and used flat washer and star washer.
- Ron Worley
+1 on the star washer... just hold her tight and use a nut driver to get that bitch good and tight....
									Ron
I think if you use just the star washer under the nut on the outside, you will have better luck at getting it to stay.
Thanks guys!..
I chopped the tab off and did what Ron said... I used a star washer, between the switch and the inside wall of the chassis, and used a nut driver to tighten the nut, so the star washer 'bites' in the metal... Works perfect!!!
- Blind Lemon
I drill the hole, some times the thickness of my face plate wont allow a star washer.
BL
						BL
