That sounds like a post PI master volume.pinkmarkos wrote:so if i am understanding this correctly... a decrease in wattage can be obtained by using a variable resistance from the PI to the output tubes. hmmm...
Break open the Rebel and map out the circuit.pinkmarkos wrote: Or would it be the resistors that feed the PI? If P(watts)= V*V/R, as you increase resistance, your wattage will decrease, assuming current remains constant. which resistors would you replace with a variable resistor and what value variable resistor would be used? hmmm...
God Bless,
