Schematic updated 2/28/09 to Rev. 1B
M Fowler wrote:Thanks to all of you for starting this tread on the DLM, it is just what I want to build as well.
Anyone with better skills than me, would you please draw up a JCM front end to SE and spec which trannies that I should used, RJ, Zippy anyone?
I would greatly be indebted to you.
Mark,
Please make a big note to self as you read the "Unverified Draft" part of the attached schematic - I don't really know if this is a good idea much less a build-able amp. On top of that it's probably got a few mistakes and there was a lot of shooting from the hip... so proceed with caution!
I'll probably start out with something like this but I can say that it's really similar to the DLM. It has a lot of plexi to it but I dropped the "B" input. I've also added a gain stage just before the master volume and note that I used a 12AY7 for the cathode follower tube as well as that extra gain stage.
The extra gain stage serves as far as a "Hot Rod" adjustment to the plexi but I wouldn't want too much of a good thing so the 12AY7 seems right... of course were not going to be able to stop some over the top shredder kid from putting a 12AX7 in there and scorching our ears with the thing... I don't know how many times you gotta tell'em, we all know all the notes and it's not a contest to see how many of them you can cram into one song - Listen to some Neal Young and see what you can do with just one note!
I've got the treble bleed feature like we read about for the DLM, but I have no idea if it's wired it up right.
I'll be curious what you actually build and if anybody builds this tell me how it works out... and what I need to change to make a good drawing.
rj
http://www.rjguitars.net
