Ok, you convinced me
Then you know it takes less than 300 ma to stop your heart or get it going again.
Even experienced builders can make a wiring error.
But they usually won't cop to it!
So your voltages still aren't where they should be, check out your resistor values, make sure you have the right ones in the right place.
Sometimes those darn color codes can be a biatch.
Knew a guy that was color blind, he had to measure everyone and label it or he couldn't tell what it was.
Check your grounds, look for missing grounds, bad solder joints, etc.
It's funny I was helping a guy with a 18 watt build and he had looked it over 100 times. He finally sent me a picture of it and I saw right away that one of the wires on the board (actually it was an under board wire) was connected to the wrong place.
I'm not bragging, it just was apparent when I looked at it.
So coming at it with a different perspective or walking away from it for a day or two can sometimes be the best thing to do. Because then you come back fresh and will see things you missed.
Good luck on it. I'm sure you'll get it right.
