Low pf shielded cable
JamesO
Re: Low pf shielded cable
Post by JamesO »
I use Sommer Spirit's, too. The eye opener for me was when I plugged a Monster Cable straight into my recording interface, then a Planet Waves, then the Spirit. The Monster came off sounding like a cheap bass through a cheap amp.
It is amazing what a good cable can do for your tone.
You can also use different cables on different amps to adjust the brightness or lack of top end.
I didn't buy into the hype for years, but once I had a decent cable it all became clear! :D
dimitris
Post by dimitris »
Thyx wrote : does anybody know of any good, low capacitance solid-core shielded wire for inside the amp?
I have found this
Don't know how good is.
JamesO
Post by JamesO »
[quote="Structo"]It is amazing what a good cable can do for your tone./quote]
I know! Not to get too far off, but now I wonder how our Sommers stack up against the Evidence Audio stuff! I'm not going to find out!
rmb550
Post by rmb550 »
I have found this
It's 28.6 pf/ft.
Spec sheet attached
BobW
Post by BobW »
really wasnt looking to bust anyones balls - but wanted to make sure I wasn't dreaming. I am over it.
water under the bridge, rmb550, no big deal. :wink:
I haven't verified it yet, but was told Canare GS-6 is what George L cables are made of.
http://www.canare.com/index.cfm?objecti ... 4EA6821ADA
although the pf / ft seems high, the frequency characteristics per the sites chart is impressive. see atachment. No noticable drop at least out to 50kHz.
That's weird because I could definitely tell the difference between the George L and the Sommer cable.
thyx
re
Post by thyx »
rmb550 wrote:
I have found this
It's 28.6 pf/ft.
Spec sheet attached
Thanks guys. Will let you know.
toneman
Sommer cable
Post by toneman »
Are the Sommer cables available state side ?
JamesO
Post by JamesO »
Definitely. I'm in California, and Tom is in Oregon. I bought mine through lavacable.com, and I'm sure he did, too.
