Low pf shielded cable
Re: Low pf shielded cable
I use Sommer Spirit's, too.  The eye opener for me was when I plugged a Monster Cable straight into my recording interface, then a Planet Waves, then the Spirit.  The Monster came off sounding like a cheap bass through a cheap amp.
It is amazing what a good cable can do for your tone.
You can also use different cables on different amps to adjust the brightness or lack of top end.
I didn't buy into the hype for years, but once I had a decent cable it all became clear!
I have found thisThyx wrote : does anybody know of any good, low capacitance solid-core shielded wire for inside the amp?
Don't know how good is.
[quote="Structo"]It is amazing what a good cable can do for your tone./quote]
I know! Not to get too far off, but now I wonder how our Sommers stack up against the Evidence Audio stuff! I'm not going to find out!
It's 28.6 pf/ft.dimitris wrote:I have found thisThyx wrote : does anybody know of any good, low capacitance solid-core shielded wire for inside the amp?
Spec sheet attached
water under the bridge, rmb550, no big deal.really wasnt looking to bust anyones balls - but wanted to make sure I wasn't dreaming. I am over it.
 I haven't verified it yet, but was told Canare GS-6 is what George L cables are made of.
http://www.canare.com/index.cfm?objecti ... 4EA6821ADA
although the pf / ft seems high, the frequency characteristics per the sites chart is impressive. see atachment. No noticable drop at least out to 50kHz.
That's weird because I could definitely tell the difference between the George L and the Sommer cable.
Sommer cable
Are the Sommer cables available state side ?
Definitely.  I'm in California, and Tom is in Oregon.  I bought mine through lavacable.com, and I'm sure he did, too.
