Please, can you take a look at it?
Many many thanks...
[img
It is not wrong. massygt6's schem is the electronic equivalent of the "grail" schematic. The only difference being that the grail schem has the wiper tied to one of the outer lugs but you can leave one of them disconected and you still have a variable resistor. Also, the only accurate HF taper values I know of come from #123 where a 500K pot goes to a .022uF cap that leads to ground.I'm afraid that your schem is wrong
You will hear different responses to the question of whether or not it matters if the cap is tied to ground or the reistor is tied to ground. Personally, I have my own answer and I'm happy with it... and it is: no, it doesn't matter.Structo wrote:Concerning the Hi Lo pass circuits, do you think it makes a difference which component goes to ground?
Meaning should you have the cap or resistor go to ground and what sonic difference would it make on the treble bleed mod?
Is what we are using for the treble bleed circuit a Low Pass filter?
It passes the lows and shunts the highs to ground?
In playing with that calculator, the lower you make the resistor the higher the frequency.
So if I use a .001 cap and want to take the high end fizz out, I should go fairly low on the resistance?
That is correct Structo.Is what we are using for the treble bleed circuit a Low Pass filter?
Yes, the important thing is that depending on where you set the resistive element it shifts the cutoff frequency.It passes the lows and shunts the highs to ground?
So say we have a 1K pot set to it's midway point (500ohms) and a .1uF cap, the filter will start rolling off highs at 6db per octave at approximately 3.2kHz. If we set it to the full resistance of 1K, the cutoff frequency is now lowered to 1.2kHz so it is now cutting more highs. The higher the resistance in the lowpass filter, the more highs will be "tapered" off to ground.In playing with that calculator, the lower you make the resistor the higher the frequency.
You most certainly want a cap to ground. If you flip the resistor and cap, you've now made yourself a low-cut filter/high-pass filter. Not cool! Unless that's what you want off course!should you have the cap or resistor go to ground and what sonic difference would it make on the treble bleed mod?
Well, if you want maximum treble bleed out of the 500K/.001uF combination, set the pot to 500K and then you'll have a high-end rolloff at 6dB per octave starting at 318Hz. Set the pot to it's midway point and he rolloff will start at 636Hz. Set it to two tenth of it's total resistance (50K) and you'll have a less agressive rolloff starting at 3.2kHz.So if I use a .001 cap and want to take the high end fizz out, I should go fairly low on the resistance?
I set mine at about 125K to ground or thereabouts. Note that my output resistor on V2B is 150K; of you use a 180K one, you may not need the treble bleed at all. I buy my trimmers at Mouser... offered in 500 ohm to 1 Meg range, if I'm not mistaken.Structo wrote:Thanks Gil, do you have any idea what your trimmer is set at?
I built a resistor decade box the other day.
I think I will insert that in my bleeder circuit and see what I get when I try different values.
I guess I could jury rig a pot in there but then I wouldn't be using my new decade box.![]()
I haven't had much luck finding a trimmer pot of the needed value in my town.
The ones I have found were very tiny and only 10K at the largest.
So until I can validate another order online to justify a shipping charge I will make due with a fixed value.
This is a D'Lite 44, 6L6, 3x12ax7UltraHookedOnPhonix wrote:Structo
What value are your snubbers? (If non-HRM)
Also, if you bias your tubes cold enough you can get a little bit of a what you're describing i.e. that fizzy sound.
What is your loaded B+? What tubes are you running?
