My first amp (express) build...
mcinku
Post by mcinku »
Probably not the right choice for my first build but I want this amp bad.
I have been inside my amps before, I'm not a complete novice, so don't worry I will not kill myself doing this. Just want to say this.
... and also, I have a really good amp tech standing by... just in case
:wink:
I bought a Ceriatone kit and trannies came from my amp tech. He has a company making trannies for his HiFi amps and they make trannies for guitar amps as well.
anyway here is a beginning
[img:1024:768]http://freeweb.siol.net/mcinku/images/g ... press1.jpg[/img]
mcinku
Re: My first amp (express) build...
Post by mcinku »
I already installed tube sockets, wire the heaters and install the pots and solder the brass rod.
This is probably not going to be the prettiest wiring around but hopefully it will sound good.
[img:922:692]http://freeweb.siol.net/mcinku/images/g ... press2.jpg[/img]
...please do let me know if I'm doing something wrong
:wink:
Abstract
Post by Abstract »
Hey, this looks familiar... :lol:
Your off and running, only gets more fun from here on.
What trannies does your friend build or sell?
mcinku
Post by mcinku »
M Fowler wrote: What trannies does your friend build or sell?
Well, he does not build the trannies him self. There is a company which is building trannies for him by his specs. These trannies are not bad at all... after all he uses them in his HiFi amps ... like this one
[img:335:241]http://www.trm-audio.si/images/ojaceval ... 300b-1.jpg[/img]
As far as I know, Nik gave him the specs for these trannies, so I asumme they are preatty much the same as Ceriatone ones.
To me, they sound very good, so I'm happy.
:wink:
Those 300B tubes have intrigued me since I first saw an amp in this guy's trunk of his classic hot rod at a car show and the tubes were lite up and music pumping, nice!
My Ipod and Zen have since replaced my stereo; however. The records are sitting waiting for me to convert them all to CDs on my USB port turn table and Audicity? soft ware. Good thing winters are long in Minnesota and I don't have a gig I can build amps and record my favorite vinyl to CD.
mcinku
Post by mcinku »
Man I'm having fun here...
Did some more work, installed the trannys, and wire those up along with the power cable and I also wired power tube sockets (almost)
[img:820:615]http://freeweb.siol.net/mcinku/images/g ... press3.jpg[/img]
8)
mcinku
Post by mcinku »
An hour later and...
...boards are in :wink:
[img:1024:648]http://freeweb.siol.net/mcinku/images/g ... press4.jpg[/img]
How am I doing so far?
I'm no expert in amp building.
I made some mistakes being in a rush. Make sure the wire on the bottom of both boards are done. I didn't do my faceplate right away and wished I had so consider that as well. Take your time and think it through. Revisit the Layout files for the Express as the wiring on the bright switch has changed.
Looks good to me.
mcinku
Post by mcinku »
M Fowler wrote:I'm no expert in amp building.
Looks good to me.
Damn I didn't see your post until now.
I managed to wire the main board tonight. Must find some shielded cable to wire the input jack.
Can you point me to the latest bright switch wiring, I'm afraid I did it the old way.
...not perfect but I'm happy. ;)
[IMG:1023:581]http://freeweb.siol.net/mcinku/images/g ... press5.jpg[/img]
Check out the updated sticky notes for Express.
gahult
Post by gahult »
Just switch center of switch to center of pot (blue wire), and move the caps to the right lug where you took your blue wire off.
Gary
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
mcinku
Post by mcinku »
Thanks guys.
What's the benefit of doing that?
mcinku
Post by mcinku »
Don't bother answering that, I found my answer.
:roll:
jjman
Post by jjman »
Is the board supposed to be so high off the chassis? It looks like the caps will hit the cover?
