the 4k/4ohms (8k/8ohms) trannie does have a little bigger turns ratio than the 4k/8ohm example. but that doesn't mean more resistance/wire necessarily. this depends on the trannie design and the internal winding geometry/pattern and it's complexity and style. if all things were equal then it would always be more resistance, but since there's the physical design involved this will vary.Fischerman wrote:This much I understand.no. a trannie doesn't have an imp.----just a turns ratio.
So...take two different OTs for example. We have a 6L6 OT that has a 4k:8R turns ratio and a 6V6 OT with a 8K:8R turns ratio. Wouldn't the 8k:8R OT have more turns...i.e. more wire...i.e. more DC resistance?
So then we decide to use the 6V6 OT with 6L6s instead. So we 'halve' our speaker Z to reflect half the primary Z...so we are at 4K for the primary. Great. But we STILL have all that wire that's causing the DC resistance.
See what I'm saying? Yes...the reflected Z is the same (and we can do things to keep it the same...like changing the load/speaker Z)...but one has way more wire and thus way more DC resistance. And we can't change that...the wire/DC resistance is fixed. This is what I'm saying may actually BE the problem. But I'm just guessing...trying to learn.
as far as the problem in this thread, i'm not sure there is one, but there could be. 10v is a lot of diff between plate and screen at idle in a push/pull class ab amp. but i'm not sure there's enough info here to diagnose. i was just answering the general comment about a higher screen than plate voltage and how the output trannie can play a part depending on the other variables (choke, tubes, circuit). rh
